Try with Mercedes Sprinter drivers.
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
I also saw VW Phaeton has EDC16CP driver, but it's 3.0TDI
tomorrow I'll try with MB Sprinter drivers and report!
I read a Crafter with Byteshooter, but i must put a kable in Pin 72 for K-Line
Ive try with all ecu drivers from mpps and did not work. Mercedes ecu is some how different. Did not have eeprom and did have piezoelectric injectors. On crafter it has edc16cp34 ecu somehow like audi a6 but did has other protocols. Also will not communicate with vag com, only with vas
@ chli1976 : Do you mind explainning the whole process.What cable, what pin? How to activate K-Line!
@ tehnosoftex So there is no way to read it with MPPS ? I know Galletto doesnt support EDC16Cp, neither does KWP2000+
Connect this pin with the k-Line from your flasher and read the file.
There is no cable to the OBD plug.
Or you upgrade a cable from PIN 72 ECU to Pin 7 OBD plug
I don't use Byteshooter, I use MPPS
Ross-Tech: VAG-COM: Current Beta
Beta 11.2 includes the following and improvements:Communications with all control modules in VW Crafter ("LT3") light trucks.
Does it work with Vag-Com 409.1 interface ? [Blue Cable]
diagnosa crafter only kts
Audi is adress ECU 01, Crafter is 91
VCDS works with Crafter
