Results 1 to 15 of 15
    Dec 2009
    Rzeszow PL, Linden NJ USA
    Default 2000 VW BEETLE DIESEL pin needed and how to match new cluster to ecu without old clus
    Hi guys
    i have 2000 vw new beetle tdi
    old cluster damaged, motorola just cracked, can't be readed
    how to adopt keys and ecu to new (used) cluster
    can somebody help me with that
    i have snap on modis with europen software and vas 5054a clone
    also i attach new cluster dump if somebody could extract pin from it
    • File Type: rar vw.rar (581 Bytes, 42 views)
    Hello!
    is this MM4 with HC12?
    try 1971
    Dec 2009
    yes it is, what about immo off, its not faster ???
    if you post ecu dump then it s possible to make immo off
    Dec 2009
    i just turned immo off, and then added key to cluster so the anti theft light will go off
    Feb 2011
    I have the same issue but the previous customer destroyed the instrument cluster instead of fixing the problem. I have a replacement cluster and the car will not start
    yugo45's Avatar
    Apr 2010
    What year and model is that car?
    Can you read and post ECU or Cluster file?
    achaccha's Avatar
    Nov 2010
    I think the solution is to make immo off, for it is necessary to have the dump of the engine ECU.
    regards
    Feb 2011
    Is there a way to figure out the IMMO code from the instrument cluster dump?
    yugo45's Avatar
    Apr 2010
    Quote Originally Posted by JandJSpeedShop View Post
    Yes if you post your eeprom file here.
  11. #11
    Feb 2011
    Quote Originally Posted by yugo45 View Post
    Do you need just the EEPROM or all memory from my programmer?
  12. #12
    Feb 2011
    Here are the files from both clusters
  13. #13
    yugo45's Avatar
    Apr 2010
    Both cluster has same pin and almost same file.
    Pin = 07170
    Are you sure you post 2 different clusters?
  14. #14
    Feb 2011
    Pin = 07170
    That PIN didn't work. Can I read it directly from the vehicle computer or turn it off?
  15. #15
    keygargoil's Avatar
    May 2010
    8280 is your pin for the first dump at the top of this post and the 2 above are 7170 and are the same pin
