Free 7day usenet account maker
Results 1 to 13 of 13
    Newbie Manny.'s Avatar
    Nov 2010
    England
    Thumbs up Free 7day usenet account maker
    Does exactly what it says on tin.
    didnt know where to post it.
    can confirm it works
    heres one i just tried
    enter the details below to test into your newsgroup server.
    Account type : XL PLUS
    Expires : 07 april 2011
    Username : xd215394
    Password : ae4ddb6c
    Server : reader6.xlned.com
    Port(s) : 119, 80, 563(SSL), 443(SSL)
    enjoy
    Mar 2011
    provided account details indeed working... time to check this account maker now
    A skip at skegs house
    As above, account details working, haven't tried account maker but shall do ltr, thanks a lot for sharing
    Sep 2010
    Everton
    Never worked for me no emails off it
    May 2008
    N Ireland
    Any info on retention, what groups it's carrying, speed, download limits etc on these accounts?
    Nov 2008
    Is this still working ?
    Worked ok for first few weeks and now I cant get email
    Member Sattalk's Avatar
    Wales
    Does this try and connect/send info in some way because it came back with this:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: An attempt was made to access a socket in a way forbidden by its access permissions 85.12.40.132:80
    at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress)
    at System.Net.ServicePoint.ConnectSocketInternal(Bool ean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Int32 timeout, Exception& exception)
    --- End of inner exception stack trace ---
    at System.Net.HttpWebRequest.GetRequestStream(Transpo rtContext& context)
    at System.Net.HttpWebRequest.GetRequestStream()
    at Usenet_Account_Maker_Final_By_Godfather.Form1.GetS ourceCodePost(String url, String postdata)
    at Usenet_Account_Maker_Final_By_Godfather.Form1.Butt on1_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4959 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Fra...7/mscorlib.dll
    Usenet Account Maker Final By Godfather
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.0.0
    CodeBase: file:///C:/Users/xxxxx/Desktop/usene...0Godfather.exe
    Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...isualBasic.dll
    System
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...089/System.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...dows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...em.Drawing.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...e.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...figuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL...System.Xml.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Fishy to me.
    Any information I provided is for educational/experimental purposeses only.
    Jan 2011
    Mazatlan, Mexico.
    Quote Originally Posted by Sattalk View Post
    mscorlib
    System
    System.Drawing
    System.Xml
    enabled.
    For example:
    <configuration>
    </configuration>
    Fishy to me.
    Did you even check the IP provided?
    Besides, you can easily sandbox and TCPView/ProcMon, easy to see what's actually being done.
    Mar 2008
    All i can say 10 posts and you downloading his links.
    There's free usenet on vm that does most, as long as its recent stuff that posted, if it older i would recommend astranews.
    Or if budget tight post in the download section - request section for what u want..
    May 2012
    dose this still work
    Jun 2012
    Default Doesn't work
    It doesn't work..
    Apr 2013
    Default Thank you
    Thank you very much
  13. #13
    Apr 2013
    good working
