Results 1 to 9 of 9
    Jun 2010
    Default Laguna 2 1.9dci EGR OFF and svbl
    Hi!Somebody help in remap laguna 1.9dci EDC15C2
    I think that egr map is 73da0!?
    SVBL need to increasein 30%?
    Jun 2010
    Default dump
    dump here:
    carmageddon's Avatar
    Apr 2010
    Italy
    on edc15 try with set on map 73DA0 all value @ 11000...if you dont have limp mode the solution is this...otherwise need disable the control but i can not now
    Jun 2010
    Quote Originally Posted by carmageddon View Post
    EGR closed but while driving limp mode;need to disable control...
    Jun 2010
    Anybody help me?
    monitel_service's Avatar
    Sep 2009
    ROMANIA
    tys is your file
    Aug 2009
    Quote Originally Posted by monitel_service View Post
    tys is your file
    Danger, bad checksum in file.
    Regards.
    Sep 2009
    ROMANIA
    What software use to write ?
    Normally your software need to make the CKS
    I can be calculated manually CKS.
    Aug 2009
    I do not problem, i use cmdflash original, calculate checksum in all ecu suported, edc15, siemens, delphi,etc, etc.
    but others, using other interfaces.
    Cmdflash only makes writing EDC15 checksum, etc.
    Regards.
