Results 1 to 11 of 11
    Mar 2011
    scotland
    Default help needed please
    hi can somebody please help? i am trying to set up my d600 when i install my cccam where do you find it to set it as my softcam. i cant for the life off me find it.
    Nov 2008
    have you sorted it
    DK Veteran reddevil157's Avatar
    Ireland
    What image you got on it
    Mar 2011
    scotland
    it was the jade image.when i ftp'd it across then went to manual instal it installed it but i could not find it after that to set it as default cam.
    Ireland
    maybe someone that runs pli will give you a shout m8
    Try yellow button....
    Sep 2010
    Link to the how to for e1 or e2
    Hope this helps you, I use pli for the VU+ duo.
    Mar 2011
    scotland
    i would be a happy bunny if i can get this set up.i am running enigma just now i can install it on there but only get all the free to air.i get the full epg and then the screen goes black which is because i dont have something set right i guess.i installed the winzip file i got and set that as my defalt and it is running on it but still no picture.i hope its just a simple mistake on my behalf if anybody could help i would be delighted.
    Ansem
    Guest
    Quote Originally Posted by readyrangers View Post
    you dont need cccam for "free to air" / FTA works just fine without it
    you need to google "cccam cardsharing" or something like that and read a bit
    Mar 2011
    scotland
    This is what i have now and still i cant get it to work.
    I have gemini 470 on it,i am trying to connect to somebody for a card share.I got the tar.gz and the config from the boy,i ftp'd them over to temp then chmod them to 777 i have tried 775 also.i then installed the tar.gz and set it as the cam.Then i do a transponder scan when it is done i just get fta i get the full epg off whats on all the channels it shows 96%snr,agc91%. along the bottom there is grey boxes with letters the one with nd is green and above what is on there is a blue dotted line it stops just over quarter away along.this probably means nothing but thought it might help can anybody help with this does the config file work once it is ftp'd to temp or does it need installed?
    thank you
    Mar 2011
    scotland
    hi again jub done still dont know what i changed to get it.thanks again
    Mar 2011
    scotland
    hi i got it sorted thanks
