Results 1 to 3 of 3
    Aug 2010
    Default renault ecu serial number help
    Hello all, need to buy an ecu for a customers car because the original one has somehow vanished from the workshop, its a 99 renault scenic 1.6 16valve petrol manual transmission, the vin is VF1JA04N520876531 have been told sirius 32N S110138000
    may be the correct one. Any help would be most apreciated
    racin-snake's Avatar
    Jun 2009
    has it got air conditioning ?
    if so you can re flash a second hand one with a off file or a clear file
    most mappings will be the same only big factor being aircon or no aircon as far as ime aware
    i have used off dumps from this vey site and had no ill effects or troubles from customers
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Aug 2010
    problem solved cheers
