Can someone help me with ECU names
Results 1 to 13 of 13
    Jan 2011
    Lisburn, Northern Ireland
    3
    Downloads
    4
    Uploads
    Default Can someone help me with ECU names
    Hey im tryn to figure out what my VW Passat 1.9TDi year 2000 Ecu type is... Ive bought myself KWP 2000 Plus China clone and would like to read my ECU and maybe in the future try to flash it if i get a spare ECU but all i can see in my list of dll's is EDC15 and different mods of it... can someone guide me through this?
    here is a photo of my ECU sticker
    UK south
    18
    Downloads
    Uploads
    it is a BOSCH EDC 15P-22.3
    Jan 2011
    3
    Downloads
    4
    Uploads
    if its not too much to ask can you give me a link or something where i could find some info about them?
    racin-snake's Avatar
    Jun 2009
    341
    Downloads
    21
    Uploads
    just as simple to just put the Bosch or whatever typ of ecu type part no into your search engine
    and it will more than likely give you the information you require
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Feb 2011
    Downloads
    Uploads
    are you trying to read it obd, is edc15 butwill only read on the bench on that model, it looks a shinny case so should have flashable chips inside some 2000 models with dull casing are chipchange only
    Europe
    Downloads
    4
    Uploads
    Quote Originally Posted by tdperformance View Post
    there is no problem to R and W these ecus through OBD
    64
    Downloads
    70
    Uploads
    Quote Originally Posted by bazaa View Post
    after the documentation that I have, your ECU is AUDI A4 1900TDI-PD EEPROM: 29f400BT
    levisdj's Avatar
    EcuLand
    392
    Downloads
    61
    Uploads
    He DID mention that the car IS : VW Passat ! And yes, it's readable trough OBD port, on some cases the dashboard fuse needs to be removed in order to R/W . Fuse N? 11 or 15 .
    Jan 2011
    3
    Downloads
    4
    Uploads
    Ive tried reading it through OBD and it didnt work.. it just said cant find ECU... but i havent removed any fuses, gonna try again soon
    Feb 2011
    Downloads
    Uploads
    Think depends on tool byteshhoter won't read obd direct to ecu only
    Feb 2011
    Downloads
    Uploads
    Only need to do fuses in golfs and boras
    Jun 2009
    Bosnia-Herzegowina, Bos. Krupa
    3
    Downloads
    24
    Uploads
    tdperformance is right, passat doesn't have on no11 or 15 fuses at all
  13. #13
    Feb 2011
    Downloads
    Uploads
    Pm me email address and I'll send bench pin out
