Results 1 to 10 of 10
    DK Veteran djjwdubz's Avatar
    dudley west midz
    Default !!slim LTplus 9504 + jungleflasher 0.1.81!! GET IT FROM HERE
    glad to see this out!!
    cunny's Avatar
    Jan 2009
    The Shoutbox
    9504 fw nfo
    C4E's iXtreme Slim LT+ in association with Team Jungle & Team Xecuter
    World first backups for XBOX 360 Slim
    - For Liteon Drive 9504
    New protection measures for slim:
    Realtime checks of drive firmware and ram by dashboard - Rootkit technology used to pass several realtime check types. These checks on the drive are open ended so as to make replay of the answers impossible. Will pass any check on any part of the drive
    Hardware flash modification check - The 1335 chip performs a hardware check on powerup for modified firmware. Chip fooled into thinking firmware is stock
    Slim drive locked to read pressed game discs only - Enabled reading of DVD+R DL media for game discs
    All features of current LT+ also included
    - Optimised PFI code to accomodate AP25 SS data
    - Defeats current AP25 protection
    - Protects console from logging AP25 violation
    - Full disc stealth used by default
    - Waveless booting , disc images are assumed to be correct!
    - Split-Vid used as default
    If booting an AP25 title without AP25 SS game will not boot but will still be protected from logging AP25 violation on current dash 12625
    If LT+ encounters an unknown AP25 challenge, game will not boot but console will still be protected from logging AP25 violation on current dash 12625
    AP25 SS are region specific for region locked games
    Thanks go to Team Jungle for their hard work and efforts in the development process.
    Thanks also go to Team Xecuter for their generous support to this project.
    Jungleflasher nfo
    PhatKey support
    faster responce reading key with x360USB ***f/w update required***
    Slim f/w support
    9504 stock/LT+ parsing, LT auto-load and key/serial spoofing...
    cross spoofing not supported
    SlimKey support
    Slim 9504 and 0225 key and serial info extraction - x360USB ***f/w update required***
    ***Note*** 0225 support is limited to X360USB PRO and other compatible chipsets
    ***Note*** via and Nforce not supported
    Slim/Phat selection
    MTK tab has selection for Slim/Phat MTK commands
    Selection is automatic based in inquiry info etc.
    Slim MTK commands added to support 9504 read/erase/write functions
    X360 firmware 18.1 X360USB PRO Firmware v18.1 - Downloads - 360Mods
    v18.1
    - Liteon Turbo Mode added. If you thought it was fast before.....
    - Slim Read / Write functions added.
    - Optimized all Phat read / write functions
    - Improved Hitachi code
    - Embedded Phatkey code - much faster Liteon key extraction with Probe 3 / PMT
    - Various tweaks and other improvements
    X360USB PRO Update Tool v0.12 X360USB PRO Update Tool v0.12 - Downloads - 360Mods
    This is the latest version of the X360USB PRO Update Tool.
    Simply move the update switch to the left (Labeled ON) and connect to USB. The device will automatically set itself up in windows - no extra drivers are required.
    When connecting your X360USB PRO make sure it says "EEPROM UPDATED" before continuing to update the firmware.
    Simply load the latest fw file and click update. Then move the switch back to its normal position (Labeled OFF) while it writes the firmware. The X360USB PRO bootloader switch should be in the OFF position at all times for normal operation.
    Click on the help tab for more info.
    Thanks to C4e TX and TJ for the releases.
    Apr 2011
    Thanks wow been waiting for this
    Apr 2011
    Thanks for the file hope it help
    Apr 2011
    Does this work on New XBOX 360 Slim Kinect? I just brought XBOX 360 Kinect - Manufacturing date is January 6th 2011.
    cunny's Avatar
    Jan 2009
    The Shoutbox
    Quote Originally Posted by pokri View Post
    Doubtfull, more than likely an hitachi 0500 drive that is non modable at this moment. Only true way is to hook the drive upto a pc and run jungleflasher. A tray comparison would tell you the make of the drive also but not the firmware revision
    Apr 2011
    Quote Originally Posted by cunny View Post
    Thank you cunny. I will check it out ASAP.
    Nov 2008
    Default cool
    does this really mean i can do my 360 slim ......
    how long before it goes tiiiits up?
    DK Veteran deffc0n's Avatar
    UK/POLAND
    Tutek and Fixkey
  10. The Following User Says Thank You to deffc0n For This Useful Post:
    narci44 (1st July, 2013)
  11. #10
    Dec 2019
    tkx man its gona hep me out
