Results 16 to 30 of 42
  1. #16
    lwood's Avatar
    city of angels
    Quote Originally Posted by credoline View Post
    Yes, i see, problem with Reset. Try to lift and try not to lift Reset, other pins do not change.
    We can continue conversation in monday, i must go in caffe bar to drink beer, tonight is best night for that.
    drink a couple of beers for me.
  2. #17
    Jun 2009
    Banja Luka Ex Yugoslavia
    My dear friend , why do you give so much pain to your self.
    Buy adapter for 0.20? , connect wires to it, unsolder mcu from board in 20seconds, and finish the job like a pro.
    I remember the times when wasn't any adapters at all (for reasonably price) , and try to imagine to write something to 29F in that way, connecting pins with wire by wire.
    Unsolder it, dont be afraid, rest is easy.
    Good luck.
  3. The Following User Says Thank You to CBR_bl For This Useful Post:
    fuzz1 (12th June, 2021)
  4. #18
    lwood's Avatar
    city of angels
    ok with help from all you guys i did. thanks.
    but now every time i read i get a different reading.
    every time i read, it looks less and less like crash dump.
    my first two dumps look like crash data i save them. what could be the cause of that?
  5. #19
    DK Veteran sl4ck's Avatar
    Youhave always to be with all wires conected between UPA and MCU, only Pin-Reset is lifted, but with wire conected to MCU (just the MCU leg is not conected to PCB board )
    KTAG, PCMFlash, Galetto FGTech V54, Smok Multitiool UHDS, I/O Terminal, Fiat/Alfa IAW Bosch Decoder, UPA-USB, XPROG, FVDI, Orange5, Renolink, DiagBox, Can Clip, Xentry
  6. #20
    lwood's Avatar
    city of angels
    Quote Originally Posted by sl4ck View Post
    yes i check all wires. i even desolder the wires and re-solder them back on. i get Auto baud Rate Success, but now when i read i get all Zeros. (See Picture)
  7. #21
    credoline's Avatar
    Србија
    PTA0 voltage not good, must be?~5V (lift pin)
    PTC0 voltage not good, must be ~ 5V (lift pin)
    IRQ voltage not good must be ~ 10V (lift pin)
  8. #22
    And i think auto baud rate should lock arround 14k
  9. #23
    lwood's Avatar
    city of angels
    I lift the three pins. PTC0. PTA0, IRQ. i get bad connection.(see picture)
  10. #24
    Resolder the pads with bad conection to the board.
    This maskset could be also MC68HC908AZ60A, you may want to read it has MC68HC908AZ60A and use the following security bytes:
    $F9-$F1-$F9-$F4-$F9-$F7-$F9-$FA
  11. #25
    DK Veteran MrWho's Avatar
    Sep 2010
    Hi Guys,
    Did anyone else had luck reading this in circut /
    What needs to be lifted ?
    Thank you
  12. #26
    mahmoudsaq's Avatar
    Oct 2015
    digital-kaos
    Hello how I can read this is for upa usp
    أرسلت من E6633 بإستخدام تاباتلك
    If I Helped,Please,
    Reputation+Thanks.
  13. #27
    lwood's Avatar
    city of angels
    Quote Originally Posted by mahmoudsaq View Post
    yes just lift IRQ.. select 8MHrz
    DON'T JUST SAY PRESS IT.....
  14. The Following User Says Thank You to lwood For This Useful Post:
    mahmoudsaq (18th April, 2016)
  15. #28
    mahmoudsaq's Avatar
    Oct 2015
    digital-kaos
    Aha
    If I Helped,Please,
    Reputation+Thanks.
  16. #29
    mahmoudsaq's Avatar
    Oct 2015
    digital-kaos
    Any adapter used
    If I Helped,Please,
    Reputation+Thanks.
  17. #30
    mahmoudsaq's Avatar
    Oct 2015
    digital-kaos
    This my upa
    Ibuy this from China yesterday
    And I cant reding 3k85k please help me
    If I Helped,Please,
    Reputation+Thanks.
