Results 1 to 8 of 8
    Jun 2010
    Default problem with ibiza 99
    hello to all.....i have problem with this ibiza........the car starts for three seconds and then stop.....i switch off the ignition and again on and car starts again for three seconds......i have no comunication to ecu or to immo with my diagostics....vag com,actia......i check all the fuses and all ok....i have +12 to immo permanent and +12after ignition..........i suppose that is immo problem...how can i make it immo off????
    ecu6k0906027 0261204844
    immo siemens5wk47740 6h0953257b
    stefaudio's Avatar
    Nov 2009
    BULGARIA
    reed eprom 27c512 and post dump
    Jun 2010
    from ecu??????????
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by d.zio View Post
    Does it have immo 1 with separate immo box under dash, follow the transponder antenna and see where it goes, if it has have a look at wiring diagram then bridge DLC & K line and see if you can get coms with ECU or just double check all earths to make sure they are good or run wire direct from DLC to ECU
    Jun 2010
    yes it has seperate immo box.......which wires have i to bridge??
    Liteace's Avatar
    Mar 2009
    On a rock
    DLC goes to immo then ECU, on 6 pin plug of immo box I think there +12v, 2 x earths, DLC in (k-line) immo to ECU, and 1 pin that is not used, use tester to see what is DLC > immo > ECU then bridge them 2 on immo box, I don't have any wiring diagram to look at, at mo. Does it have airbag and can you coms with it ?
    Jun 2010
    THanks mates.....solved....
    was the ecu.....i reclased with a second hand,made the adaptation and all ok......
    THANKSSSS
    Liteace's Avatar
    Mar 2009
    On a rock
    THANKSSSS
    Nice to see you got it sorted
