Page 1 of 3 123 LastLast
Results 1 to 15 of 38
    Oct 2008
    Default Edc16c3 with xprog m
    Hi, i need help connecting xprog with edc16c3 with x prog.
    Bulgaria
    Quote Originally Posted by AMON View Post
    I make this!!!!!!!!!!!!!!!
  3. The Following User Says Thank You to choro For This Useful Post:
    leandroks (8th April, 2015)
    hi
    how can i get connection diagram of all ecu s
    Bulgaria
    I work only with this
    pirilla's Avatar
    Spain
    One question:
    How do you apply 12V, from external supply or from X-Prog ???
    Thank you in advance.
    Bulgaria
    I find them every time with multimeter front of the jack
    pirilla's Avatar
    Spain
    Sorry, I did not explain well.
    My question is if you use an external supply to apply 12V or if you use 12V output from X-Prog.
    I suppose you use external supply and you connect 12V and GND in ECU-PLUG. Don't you?
    Bulgaria
    Quote Originally Posted by pirilla View Post
    Yes use external supply and connect 12V and GND in ECU-PLUG.
  10. #9
    Oct 2008
    I have used external supply and manage to read it.
  11. #10
    pirilla's Avatar
    Spain
    Someone with PLUG PINOUT ???
  12. #11
    Oct 2008
    just connect +12v to pin 2 and 9, gnd to pin 6, and you will read it
  13. #12
    Oct 2008
    don?t need to use ecu plug pins
  14. #13
    pirilla's Avatar
    Spain
    I understand. But I would like to read through K-line too (if possible on the table). I want to know with is better for this.
  15. #14
    Oct 2008
    found this one but could not connect
  16. #15
    pirilla's Avatar
    Spain
    This is for EDC16C34, FAP engine version, not same as EDC16C3.
