Results 1 to 9 of 9
    Oct 2010
    Default setting up a motorised dish
    I see ,read . setting with diseqc and /or usals . Is there a best /easier of the 2 . I am just now gathering info on setup prceedures . Obviously I am a newbie
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Quote Originally Posted by camslangman View Post
    Usals is way easier,all you need is your Longitude,Latitude in Simple Positioner mode add Sgtflipflops latests bouquets and away you go.
    I didnt even scan all worked fine.
    Andy.
    Nov 2008
    USALS is by far the best way to go go although a lot of dm500s dont work with USALS, requiring you to manually search for the satellites
    Oct 2010
    my fear is I do something stupid and can't find how to reverse it do you just hit reset defaults or go back a step at a time
    Aug 2010
    East Midlands
    What box is it on?? Really easy on a Dm 800 hd.
    Andy.
    Oct 2010
    Quote Originally Posted by andy91 View Post
    Andy.
    It is a dm 800 hd , I hope it is easy I wll adjust my dish a little first
    Aug 2010
    East Midlands
    Go on dishpointer and put in your full address it will give you your correct Long and Lat.
    Make sure they are correct and ftp the latest set of bouquets and you will be fine.
    Andy.
    Member mickm1's Avatar
    Feb 2011
    uk
    Did u get a new dish then joe? Im assuming thats u goin with that name
    Like 1 of the previous posters said, go to dishpointer website and get ur long/lat and put those into the settings. U will also need to adjust the satellite on the bracket. And i hope uv got that pole plumb!!!
    Oct 2010
    I hope so too . I should be ok I f--d about with spirit level and got it plumb ok
