someone tell me if the microcontroller used in the ecu MARELLI IAW7GF is MOTOROLA or STMICROELECTRONICS?
someone also knows an interface to read and write this ecu?
Hi, is Motorola
autrobr,
you can tell me the part number or mask of this motorola ?
Mac cever !
That is Hc11
Cardoctor, is NOT HC11
More info PM........
NEED TO RESET THE FIAT 7GF.
TKS
The processor is FREESCALE MPC553. You can read it via J-TAG with K-TAG for example.
How can i immo off this ecu somebodi kmows thankas advance
Enviado desde mi SM-J200M mediante Tapatalk
Hello that, you need to do the procedure with the UPA, 7GF Reset is called, active and you record it in the memory of the ecu itself, change some lines, place the ECU the car in contact and it is paired with the BODY, greetings.
RESET VIRGINIZE MM MARELI IAW 7GF.NL FIAT FIRE 1.4
PUT THIS ON THE LINE : 0000D0
47 16 FF FF 00 00 00 00 10 D4 FF FF 00 00 00 00
AND PUT FF ON ALL THIS LINES:
0001E0
0001F0
This is a reset procedure for this ecu!
Test by yourself and press thanks. sorry for the bad english...
BRazil!
MentadoPlus (5th May, 2019)
