    Oct 2010
    Default How to put BISS key
    hi all
    I am wondering how to put manually BISS key on my openbox s9.
    hi
    sorry for now biss key not work openbox s9
    only
    irdeto and cryptworks,
    emu can be next
    Jun 2011
    Default IT?s Simple
    Quote Originally Posted by sombel View Post
    hi all
    It's simple
    if I violate any rules with this guide I apologize to all ...
    no USB remote control
    Menu, network setup, client setup CCcam
    Manage config files
    Constant.cw
    Add (green button) displays the fields to get information
    CAID, PROV ID, SID, PMT PID, ECM PID, CW EVEN, ODD CW
    We obtain the above information sheet in exel this post right here
    In the yellow fields exel sheet put the channel name, SID and PID VIDEO and you generated in the bottom of the sheet exel data that you put the receiver in the row of constant.cw.
    Example: Intelsat 805 (55.5W)
    You put in the yellow fields exel sheet
    channel name: tele-once
    SID: 140 (get it by pressing the blue button 2 times to be s / channel)
    VIDEO PID: 141
    Biss key: 1371130037111300
    At the bottom of the sheet in exel constant.cw genre you:
    2600 000000 0082 1371130037111300 0083 1371130037111300 1fff is information that asks the receiver and you should get w / remote control
    CAID 2600
    PROV ID 000000
    SID 0082
    PMT PID 0083
    ECM PID 1fff
    EVEN 1371130037111300 CW
    ODD 1371130037111300 CW
    you press yellow button (config) You give ok and then exit and go to watch t
    Member althom40's Avatar
    Scotland and Portugal (37N 7.8W)
    Wow! to enter a BISS key you need to do all that.
    Think I will use my Technomate for this.
    Find the channel.
    Sys Info/BISS enter keys on a spare line, thats it.
    May 2013
    Quote Originally Posted by tangoindia View Post
    It's simple
    Manage config files
    Constant.cw
    VIDEO PID: 141
    CAID 2600
    PROV ID 000000
    SID 0082
    PMT PID 0083
    ECM PID 1fff
    Where is the excel sheet mate ?
    DK Veteran slugworth's Avatar
    Nov 2011
    new england
    the lan manager help files show the correct format for openbox
