Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Ashraf6119's Avatar
    UK
    Noooooooooooooooooooooo, You are NOT Right
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  2. #17
    koziolek's Avatar
    Under the car
    Can someone provide me with useful info?
  3. #18
    sweden
    Default Maybee
    it's shit behind the steering-wheel , simple solution one piece of wunderbaum .
    learn 2 thank people for the work they do here
  4. #19
    Liteace's Avatar
    Mar 2009
    On a rock
    Whats the engine code ?
  5. #20
    Ashraf6119's Avatar
    UK
    1) The Cam Actuation works with Oil Pressure..........If your Oil Pressure is Low you will have this fault code...
    2) This model are very common to for Oil pick up pipe in sump to block and cause low Oil pressure..........so worth checking or oil pressure............
    3) I know is might sound odd but if your fuel pump relay is faulty will also trigger this fault code..........
    4) There are still many more things to check for that fault code but,,,,,,, this is OK for now for you.................
    Thanks Ash
