Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Default CLIO 2 ABS LIGHT ON AFTER MOT
    just dropped a customers car off at the mot station and now the abs lights on ?
    checked ecu codes and came back with o/s/f sensor so changed it and still the same and same code ?
    so have they by checking the car on the ramp with ignition on caused this and if it has will it clear or is there something else l need to do
    punters havin a strop (as u would )
    anyone else had this and its cleared on its own . l have cleared codes even after fitting new sensor but still there , have checked in live data and no signal from that wheel at all
    Sep 2009
    Maybe they damaged the wiring during the inspection or disconnected a connector?
    Mar 2008
    birmingham
    Quote Originally Posted by oldford View Post
    checked all where he would of checked and talked to the mot lad aswell
    drakov's Avatar
    Aug 2008
    toothed ring on cv joint may have snapped when going onto the break tester if it was very rusty/corroded
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Mar 2008
    birmingham
    Quote Originally Posted by drakov View Post
    checked it m8 its fine ?
    Meat-Head's Avatar
    french, cure on fault, gain another.
    we had a laguna in once, abs, some dumb~~~~ had subframe off, and trapped wire, but needed a telescope to see that it was trapped.
    there is a common fault on clio abs, check bbareman.chunts
    have you tried a 'high speed' had a shitty crysler in, short story was, 'new' sensor (didnt tell punter was a used one), light on live data said yes, give it large, went out.
    Mar 2010
    Different
    I prefer to connect one cabel from abs ecu connector to example ohm meter and other to sensorside and look at display while twisting, bending, pulling.....
    Best is when draw little and ohm dropps and drag like hell and you got the cable in 2 pieces.
    DK Veteran teuton's Avatar
    Nov 2009
    Mexico
    you might wanna connect your DMM or scope to the unplugged sensor to know wether there is actually any sensor output or not when wheel is spinned . So you would know if you got a faulty (even new) sensor or if it's a wiring/controler issue further upwards.
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
    Sep 2008
    i presume a drive did not reset it also,anything inside engine compartment they were checking,does sound like a break somwhere.
    Ashraf6119's Avatar
    Nov 2009
    UK
    What is the fault code Is it coming up as an Open Circuit or as an Mechanical fault...........Also will it clear and come back when you drive it or, it will not clear at all..........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  11. #11
    Mar 2008
    birmingham
    It's clears but as soon as u drive it's back on and in live data there's on signal from that side
  12. #12
    Meat-Head's Avatar
    Quote Originally Posted by Mrubbert View Post
    Quote Originally Posted by teuton View Post
    OFF TOPIC:-
    Late VW, Ford, Crysler the abs sensors are powered by 12 volts and talk back via the power supply - (super imposed) - the sensors are 10000000% OPEN CIRCUIT untill powered - too last to use an ampmeter to test.
    ON TOPIC:-
    Sounds like abs modulater is ~~~~ed, like Rough-ash1111111969999999 said
    does it said 'mechanical fault' or 'open circuit'
    try another scanner, as you have a Snap-Off pile of poo.
  13. #13
    Ashraf6119's Avatar
    Nov 2009
    UK
    Check the Air Gap between the sensor and the pick up ring might be big.........
    what tool are you using to read and what's the fault description is it saying as open circuit or mechanical fault
    Thanks Ash
  14. #14
    Mar 2008
    birmingham
    Snapon modius and it just says front right sensor . The gap is fine and as l said it was fine on the way for mot as l drove it and when l picked it up the light was on and it didn't fail on that
  15. #15
    Ashraf6119's Avatar
    Nov 2009
    UK
    Try cleaning the Multi Plug on ABS Module also see if you can get hold of Clip read the fault code to see what says by clip.....
    Have you check the wirings to ABS Module if its not broken.....
    Thanks Ash
