Results 1 to 7 of 7
    V.I.P. Member mickydibble's Avatar
    Nov 2008
    modsvilla
    Default Barbeque plates rusty
    Plates on barby rusty due to being left uncovered by wind, what's best to do to remove ? Thnx micky
    V.I.P. Member Evastar's Avatar
    Apr 2009
    Je ne regrette rien
    i take them out and use oven cleaner, leave it on for a couple of hours and then scrub with a sponge and then rinse.
    after they dry, oil them with vegetable oil and put them back.
    Nov 2008
    modsvilla
    Cheers EVA
    Mar 2011
    Essex
    make sure you clean and re-oil before usage as veggie oil will go rancid.
    If you want to, you can get porcelain coated plates which are more non-stick and don't rust.
    DK Veteran SouthernComfort's Avatar
    Feb 2011
    Nirvana
    Or store cooking grill in airtight bag after use, cheap but effective.
    daithi's Avatar
    May 2009
    ireland
    oven pride is the dogs danlys on it mate
    Nov 2008
    modsvilla
    Thanks peeps will take your suggestions thanks micky
