Results 1 to 15 of 17
Hybrid View
    DK Veteran kelekele's Avatar
    Sonta,Serbia
    Default x431 Diagun erased microSD card
    Hello!
    I wanted to backup files from x431 diagun memory card and I deleted all contents of them.Now can not use the device at all and I have no update.
    Thanks in advance!
    Oct 2008
    On Earth
    Quote Originally Posted by kelekele View Post
    Hello!
    I wanted to backup files from x431 diagun memory card and I deleted all contents of them.Now can not use the device at all and I have no update. If somebody have diagun with the s / n: 980540191000 and if possible upload the entire contents of the microSD card somewhere?
    Thanks in advance!
    Why don't you ask your suplier?
    He must has your S/N updates.
    If he dosn't please contact me in PM and I will tell you the way to make your tool back to life.
    Good luck
    Sep 2011
    hi. can u help me ?
    i need a new backup for my device because all in the micro i deleted, can u help to get it working again ? thanks
    Oct 2008
    On Earth
    Quote Originally Posted by m1ghty View Post
    hi. can u help me ?
    M8 did you make a back up of your SD card?
    If yes you have just to copy the GAG folder back to your card.
    If you ever did this...in this case it is a littel bit complicated but it can be fix it.
    Good luck
    Sep 2011
    i do but it not working, now i cant se any logo of the vecihles.
    can u tell me i have 2 map 1 call vecihles and the other call smartbox when i open it op shall the name of the map rename to DGAUDI, DGBMW, DGBENZ ect. ?
    Oct 2008
    On Earth
    M8
    I don't understand what you did there but you need to have a GAG folder and for Digun and in this GAG folder you cannot have smartbox. Ok vehicle folder you must have an in it you have to have DGAUDI, DGBMW or others but don't rename item.
    ( from what I know smartbox floder folder if you have that one is for Master, GX3 or Old Scanner not for Diagun )
    Good luck
    Mar 2011
    Default supply S/N number
    Quote Originally Posted by mattydr67 View Post
    Good luck
    yeah, I agree with you, give your supplier S/N and they will supply you the program.
    Sep 2011
    Thxs mate.
    do u have a new update for diagun ?
    Oct 2008
    On Earth
    Thxs mate.
    Mate my Diagun has the lastes updates, becasue my supplier can give me that.
    Good luck
