hello
can any one know how to turn off the low beam of this car its always on
this is the long coding of central electronics 09 of this car can any one help please
48180A3E9825F3C0408800842400892443550088736D8D6064 8000200000
hello
When you say low beams always on, your talking about daytime running lights or they are just on all the time with the key out and the door locked??
when key out or switch ignition off,light go off,
i think its an optional but how can i turn the light on and off with a switch and where can i find this option
thanx
Easy assuming you have European switches. Ignition off lights set at 0 turn left hand indicator on and pull for main beam turn ignition on and wait for 6 clicks of indicators ignition back off job done to reactivate do the same again only with right hand indicator.
If you have xenon's, you must use VCDS to disable them / lower them.
If you have HID Xenon's its not recommended as this is not good for the ballasts.
thank you very very much, this is what am looking for exactly ,the car is with xenon lamp can i do it with manual mode or i need to do it with vcds,
and do you have the steps how to deactivate it on vcds
You cant change it via switches if its not halogen (at least i don't think you could try doing it with my last post)
Open vcds and select central electronics - 09 then under Advanced- Functions your looking for Coding - 07
You need to edit byte 11 which in your case should be 48180A3E9825F3C0408800842400892443550088736D8D6064 8000200000
Change it so the box Bit2 [Daytime Running Lights (via low beam) Active] is unchecked.
If you have halogen and don't do it through the switch then its Byte 15 you need to edit.
How did you get on with this as I own a 2009 halogen and that's easy through switches. It would be nice to know if this worked for you??? MH I respect your thanks as you seem to give respect where respect is due. And you give a shitload of good info. ok it may be in rhymes but its always good.![]()
sorry but am not test it till now,
when i test it .....post result
