New VIX Image - v1.0
31/10/2010 - OE1.6
From VIX Team
Based on Official 5.3 Image
Enigma: 04-10-2010-experimental.
Enigma Plugins: 04-10-2010.
GCC Version: 4.4.3.
Team VIX Enhancements
This image has been written based upon bringing similar functionality to the vu+ solo as the vu+ duo... Andy's been busy optimising code from the duo to ensure that it works just as great and well in the solo Big thanks to andy :lifting:. Anyway, here's all the functionality:
  • VIX Solo 1.0 Bootlogos, Radio Logos and Shutdown Logos.
  • Softcam Manager completely re-written to allow users to add any softcams that are not currently available in the plugins server. If a script is not necessary, then you can just copy the binary file over to /usr/softcam/. This will allow you to use the binary. If you need a script, then andy will explain how to do it . Also, with the new softcam manager, softcams will start in the order in which you add them to the autostart. So, if you want oscam and cccam to autostart, if you add cccam first, then oscam, cccam will always start before oscam (basically, pointless ). So, make sure you add them in the correct order!. Also, some users need mgcamd to update entitlements (and other similar cam usage might be required). So now, if you want to stop a cam, the autocam checker will not check for stopped cams. For example, if you stop any autostarted cams, then start mgcamd (or whichever cam is not autostarted) manually, this will stay running until you either manually stop it and start the required cams, or restart your box.
  • VIX Device Manager optimised to work with the solo image.
  • VIX Image Manager - Allows you to take backups of your current image and restore the image.
  • New IPK Installer, just copy your .ipk fle into '/tmp' and goto the menu option.
  • VIX Overscan fix - If the menus do not show correctly on the screen, you can alter the numerical value in the Skin Settings menu, to change the location of the menus/items on screen to show the whole menu.
  • VIX Swap Manager - Works with swap partitions and swap files. If you want to use a partition, you will manually need to create this yourself . For swap files, file sizes are limited to 64mb, as this is plenty for a swap file, and to enable stability with the solo image.
  • RyVIX EPG Grabbers.
  • CrossEPG Grabber - Includes latest image patch to import data without need for a restart.
  • EIT, MHW, FREESAT & VIASAT EPG Download.
  • Cron jobs supported - create the "root" file with the jobs you want to run in '/etc/crond/'
  • Autotimer image integrated in to image. Work has been undertaken to ensure that autotimers search all info to ensure that it picks up all available epg data to catch an event... Seems to be working great :thumbsup:. Also, when you add an item to the autotimer, it will do a scan straight away to add all items to your timers. Finally, scanning for new autotimers will only take place when your machine is in standby mode. option can be turned off in settings.
  • CoolTVGuide: by Coolman, integrated to image - Use epg button to load.
  • CCcam Info - Written specifically for image to help speed up skin loading. This is mainly used for the second info bar .
  • Recorded items list modified to allow moving of items, browsing directories, etc. Works similarly to suomipoeka plugin. Can be selected to load via the recorded items button, or from the tv button.
  • Permanent Timeshift Plugin integrated (Disabled by default, turn on via Timeshift settings).
  • Integrated VirtualZap (long hold of OK button).
  • Integrated EPG Search (yellow button).
  • Update Manger - Use the online updates to update the image to the latest fixes.
  • Wireless LAN Support
  • Smargo Support
  • Panic Button - Goes to channel number 1 in your channel list and clears browsing history
Button Mappings
  • Short Red - Show current event info.
  • Long Red - Show current channel EPG info.
  • Short Green - Timers.
  • Long Green - AutoTimer Timers.
  • Short Yellow - EPG Search.
  • Long Yellow - IMDB Database. < --- Currently not working - read Known Bugs
  • Short Blue - Extensions.
  • Long Blue - Plugins Menu.
  • EPG - Opens the Cool TV EPG plugin
Known Bugs
  • IMDB Plugin not working correctly - This is a problem with the original plugin, and as soon as an update is posted which fixes this, it will be made available via an online update...
  • Motor moving image does not display - Problem with main driver, reported to VU+.
  • Front VFD display showing the play button at the end of a video unless it is stopped manually - Problem with main driver, reported to VU+.
  • ECM time on second info bar in skin is not currently shown - New version of CCcam needed for OE1.6. (libgcc_s.so fix is unstable).
  • Installing other skins may cause the box to get into an infinite loop. Only skins in the feed are tested and recommended by us. If you want to use other skins, you will need to use OE1.6 skins (i.e. those created for VTI 2.0 or later), and may need adapting for the image (espcially in terms of the CCcam info displaying on the second info bar)...
Screenshots
Downloads
NFI:
http://www.mediafire.com/?2whm9kqyadi97km
USB:
http://www.mediafire.com/?dbu4yj6g6wfrukt
