HD Glass 16 skins by shamann - Page 4
Page 4 of 6 FirstFirst 123456 LastLast
Results 46 to 60 of 80
  1. #46
    Sep 2010
    HD Glass16 ver. 2.77
    - added support for BH 1.6.1 VU+ (older removed)
  2. #47
    Sep 2010
    HD Glass16 ver. 2.79
    - added Memory free/total and Cpu load - can be enabled via setup - when autocolor is enabled, color of the mem/cpu is changed by value of theCpu : N/A - blue, <25 - green, <50 - yellow, <75 - orange, >75 - red
    - changed method to calculate cpu load - user info
  3. #48
    Sep 2010
    HD Glass16 ver. 2.80
    - fix channel number(converter), when channels with equal name are used in more bouquets (sat positions)
  4. #49
    Oct 2010
    I couldn't contact them, at the link you gave me, about the Event names problem I have. Could you contact them for me or give me a URL so I can do it?
  5. #50
    Sep 2010
    Quote Originally Posted by thermosiphonas View Post
    that forum is no longer in existence
  6. #51
    Oct 2010
    So, can you please tell them about this problem?
  7. #52
    May 2011
    Default Event names problem
    Where is the problem
  8. #53
    Oct 2010
    As you can see in post #38, when the event names are in Greek and not in Latin characters, they are cut short
  9. #54
    Sep 2010
    i no longer know of a forum where he can be contacted as both the Italian forums i knew him to be on are closed.
  10. #55
    Sep 2010
    HD Glass16 ver. 2.81
    by shamann?
    - enabled menu item rotation (from last to first-key down and from first to last- key up in all types of menu
  11. #56
    Default Hd glass
    Just quick question. Loaded this skin and it's fantastic but cant seem to work out the menu rotation. When I click menu and to move around up goes down, left goes right....
  12. #57
    Sep 2010
    Quote Originally Posted by wizard55 View Post
    yeah i get the same thing. iv'e moved on to the vali hd flex skins now.
  13. #58
    Sep 2010
    HD Glass16 ver. 2.82
    by shamann?
    - fix sid in ecmline, if caid is enabled
    - changed the label "hd glass16" to Video pid, audio pid - if bitrate is disabled
    - small fixes in all screens
  14. #59
    Sep 2010
    HD Glass16 ver. 2.83
    -added auto-detecting hdd / manually enter for detection hdd temp. in User Sreen - change settings is available in the setup of the skin - in the User Sreen temperature is showed, but the message may appear if in setup is bad path to hdd (shown in the setup N / A), priority detection is set as follows: 1 specified in the setup if not, the second try a hdd detection of management-by Enigma
    - added autorefresh (according to the enigma of events) to see the Video PID, Audio PID
    - correction Vpid, ApID Sid and the shape of XXXX, if detected length 2 or 3 and display N / A if indicated pids are not available (error)
  15. #60
    Sep 2010
    HD Glass16 ver. 2.85
    - changed priority to get hdd temp in user info
    HD Glass16 ver. 2.84
    -added universal bin to get hdd temperature - autodetect and manual ( images without smartctl and with broken enigma hddmanager)
