More posts required.
help
Another leecher, ~~~~ing hell there everywhere.
please help ive try all above but no joy ive put on usb but its not showing up on my tv patch ok addon ok please help
Welcome to Digital Kaos.
thank you very much!
And welcome to you as well.
Hi I can't get secret menu ,either by 8281 or ip button
Please advise
thank you
Welcome to DigitalKaos.
thank you for all the info its been helpful
Hello, everyone, noob here, your probably sick of hearing it . Anyway i've read the pdf file and done everything and patched it etc, then it says about entering some numbers, which i do, which takes me to the menu, looks like of channel settings, doesn't look english to me, what do i put here? i havent a clue sorry. or do i just do a blind scan?
thank you for reading this
Hi all, just a quick question I have installed the addon file and everything is apparently working fine, what I would like to know is what kind of cccam am I using? I have been ask this question and I haven't got a clue where to look for this kind of information. Many thanks
that would be cccam 2.0.11 and if they say to change it ,well you can't.
And 2.0.11 works perfect anyway with most servers,if it doesn't work for you it will be more then likely a bad server or you will have to stay/goto an older patch like 117 for some reason newer patches don't clear some providers very well.
Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
