Results 1 to 15 of 16
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Default Zafira 2002 warning light problem
    Hi Guys
    got a problem with a Zafira 1.8 (2002) where it has a picture of a orange radiator and star on the dash which seems to be a cooling issue so tried to read engine codes but unable to read codes for some reason from engine ecu is it possible if ac module is faulty it stops communication with engine ecu.
    so basically warning light stuck on,no ac,no ac fan,no cooling fan and all fuses etc seem to be fine so just wondering if anyone else has come across this
    Ashraf6119's Avatar
    UK
    Have you tried reading the fault codes from the Cooling Control Module and see if there are any fault codes in there ?...........
    Any faults with A/C System will not stop you to communicate with Engine ECU........
    There might be some other problem which you would not communicate with Engine ECU...........
    What Tool are you using to read anyway ?...........
    Have you also checked the Coolant level to see if its not low ?............Also what's your Coolant Temperature readings are ?...........
    Low A/C Refrigerant (Gas) will also some times trigger that light...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Hi Ash
    only had my modis onboard with me so maybe better to try with op-com but the guy said his ac has been fine but no fan,no ac seems to have all happened at the same time also temp sits about 85 ish but will boil up as it did the other day on the guy whilt in traffic all levels seem fine
    Ashraf6119's Avatar
    UK
    I am sure there must be some fault codes in Engine ECU also in Cooling Control Module which could give you some glue...........Just get the rite stuff to diagnose it and go from there........
    Thanks Ash
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    no option to read ac module on snapon modis but should read ecu fine but will try again with op-com as i know that has the ac module option
    Meat-Head's Avatar
    bump
    as a rule cooling fans on cars with a/c - see if you can activate them
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    bump
    didnt have op-com with me on the day so didnt have that option
    The A/C module is located behind/front left wheel trim and they get water damage quite ofter, you could have a quick inspection of it, best to put car on a ramp so you can find it from underneath.
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    thanks mate but checked that as seen plenty on astras with either that or smashed from previous accidents
    PierreTheron's Avatar
    Centurion,South Africa
    Have you considered that fault might be in engine ecu??
    Try to put side ways pressure on the ecu plugs by hand and see if any warning light changes on dash... Just beware this can make ecu to break down completely and might make vehicle not to start any more.
    Pierre
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Did try that and looked for any contamination inside plugs but nothing
    Meat-Head's Avatar
    sorry, just looking at ~~~~, try turn on a/c see if fan cut in
  13. #13
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    tried that also so but no joy but comp is cutting in so no need to get me guages out to check for pressures and i could maually probe the fans with a power probe and they would try to run before tripping me probe but the allowable current on probes are not very high anyway so i would expect it to trip
  14. #14
    vuno01's Avatar
    Europe
    just a thought
    i had a seat ibiza that hapenned the same thing
    turned out to be the outside temperature sensor
    what means that if the outside temperature is below
    5 degrees celsius the ac doesn't turn on.
    try to locate that sensor and heat it a little with
    a lighter and try to connect a ac again and check if the
    light in dash goes away because that light might be a warning for possible frozen road or frozen cooling.
    try this and report back.
  15. #15
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    sensor is fime it is showing 18oC on dash but yes i know what you mean i had the before with a 2005 530d bmw showing -41 degrees hence why it wont allow ac to run
