Page 13 of 25 FirstFirst ... 38910111213141516171823 ... LastLast
Results 181 to 195 of 361
  1. #181
    kautuvera's Avatar
    Default Xprog
    I will do anything to make this device is silent error
  2. #182
    city
    Default xprog
    you update 1er whit xprogbox ok????
  3. #183
    kautuvera's Avatar
    Quote Originally Posted by martin292009 View Post
    what ? please help me
  4. #184
    einet's Avatar
    I ~~~ed my clone xprog yet!
    I make update over xprogbox and then i run xprog!
    Device silense!
    What i can do?
  5. #185
    kautuvera's Avatar
    I do
    But the result was not
    Again the same error
  6. #186
    makura's Avatar
    First replace the file into the xbox folder and run device update,do not use xprog 5 for the update procedure,you will get device is silent error.after when the update is done,delete or uninstall xbox and delete its folder from your drive C/and re-install your original xprog-m software and use as normal.
  7. #187
    DK Veteran Carsoft2003's Avatar
    Mar 2011
    Algeria
    Hi pass my friend
  8. #188
    makura's Avatar
    Quote Originally Posted by Carsoft2003 View Post
    Hi pass my friend
    Take time to read through the thread.You will find one with out a password.
  9. #189
    Mar 2011
    Algeria
    Thanks a lot of Makura , I test your file work fine
  10. #190
    einet's Avatar
    OK Thanks MARTIN.
    My Xprog-M work again.
  11. #191
    city
    Default Ok!!!
    Ok bro. Regards.
  12. #192
    einet's Avatar
    what is the benefits to make update to xprogbox and back to xprog-m?
    Are the firmware new?
    Orguinal?
  13. #193
    Jun 2009
    if you wan to read and write the processors mc68hc11, 705,05 you must use a resistor 1-10mohm parallel to the crystal .
    this is the reason that xprog can writes with mystake those procesors,
    do not trust the chinese adaptors ,make your owns adaptor if you want to have good results
  14. The Following User Says Thank You to gadroulll For This Useful Post:
    mexanico1971 (4th September, 2016)
  15. #194
    einet's Avatar
    can you give mor info about home make adapters?
    resistor 1-10mohm parallel to the crystal on the adapter or on xprog pcb?
  16. #195
    dimitar's Avatar
    Quote Originally Posted by einet View Post
    Put resistor at the adapter crystal so it wont make the frequency floating
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  17. The Following User Says Thank You to dimitar For This Useful Post:
