Page 6 of 25 FirstFirst 123456789101116 ... LastLast
Results 76 to 90 of 361
  1. #76
    DK Veteran elchip's Avatar
    EU
    Post
    Quote Originally Posted by matekhr View Post
    Here is my idea about authorizations:
    Attached screenshot shows extracted eeprom part of "elchips" firmware file. (sorry, elprog, I have to put a screenshot here, I can't explain without the picture).
    Looking at the marked part, you'll see it consists of 5AA5 and A55A blocks. Now look at the authorizations screen of our xprog-m programmer. In case of full authorizations, we'll have total of 22 lines, 9th line is "Development tools" and shows "-" instead of "authorized". ARM micronas are two last lines, which are not authorized in our case.
    Now look again at our screenshot - let's make a presumption that 5AA5 means "authorized", and A55A means "not authorized" or "-".
    That idea works perfect for first 15 lines - we have 8 authorized lines, one not authorized and then 6 authorized.
    Now comes a little messy part: 11 A55A's, 3 5AA5's, 1 A55A, 2 5AA5's and finally 8 A55A's.
    Counting in total, we have 19 "authorized" lines (what is good), and we need 21 to make ARM micronas authorized, too.
    According to that logic, two of eight A55A's in last "unauthorized" block must be changed to 5AA5 to become "authorized".
    Maybe I'm totally wrong, but somehow it seems to me this could work. Because I repaired my xprog-m programmer in other way, and now works 100%, I would like someone (Bram380 maybe?) to test my idea.
    Of course, I don't know will this work at all, what about checksums etc. - it's only an idea...
    So soon or later XprogM will be demystified or maybe it is from now...
    It is so nice look step by step how thing go on in forward direction ...
    Now you can experoment with it unlimited ...
    Maybe I was do wrong thing .
    All the best
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  2. #77
    bram380's Avatar
    Indonesia +628153111774
    After several trials, finally managed to fix xprog-m with 21 authorized.
    Thank you for your assistance elchip & matekhr
  3. #78
    EU
    Post
    Quote Originally Posted by bram380 View Post
    Nice to see that mate.
    Have a nice time and good job.
    >> Can you report did you test HC05-HC705 with that FW <<
    Regard's
  4. #79
    matekhr's Avatar
    Croatia
    Excellent job.
  5. #80
    EU
    Cool
    Excellent job.
    So now no more problem's with that tool ...
    " DEMYSTIFICATION SUCCESS "
    Regard's
  6. #81
    bram380's Avatar
    After reprogram, read & write be-em-we ews is okay.
    But not test with hc05.
    Repair Xprog-M requires a lot of time, thought and a suitable tool.
    I recommend buying a new xprog-m genuine or clone.
    It's no more just a matter of knowledge that should I get,
    and certainly I do not have enough money to buy new
  7. #82
    Dunker's Avatar
    Yorkshire
    I've been away on holiday for the last week or so and I have missed what has been happening here. It looks like elchip posted a dump of the Atmega that has now been withdrawn. If so, how was the dump obtained (just a rough explanation if possible). More importantly, can anyone tell me if there is a way now to get a full dump from an Atmega48V MCU. I have been wanting to take a look at the code in a certain Atmega48V for a while now.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  8. #83
    DK Veteran agabna's Avatar
    hello
    thanks all
  9. #84
    I recommend buying a new xprog-m with activation code which the price of euro438 only.
    hello
    yes it better to buy new one but the cost is too high
    so it better to buy new clone one with 80$ dollars and try to work on how to register xprog-m like we update it to 5.3
  10. #85
    hello
    now they had new software v 5.3.5
    ELDB
    could u report about it our try to test it
  11. #86
    I changed 5.0 software to increase the CDC32XX-24C32 TOOL
  12. #87
    ovi_dk's Avatar
    On board
    Hi guys,i download the new x prog soft 5,3,5 and i copy all program widawth ,,exe,xlm,html,,in x prog m v 5 and all works ok
    Dont forget wath say Bram380 dont copy exe xlm,htlm and dont give update and your x prog stay with full autorization.
    Gud luck..
    If u have the answer say Thank You!!
  13. #88
    ALGERIA
    is there a change befor and after update?
  14. #89
    Quote Originally Posted by ovi_dk View Post
    Gud luck..
    This method, CDC32XX-24C32 TOOL is not working !!!!!
  15. #90
    ovi_dk's Avatar
    On board
    For me its a change after update becouse i update direct from 5.0 to 5,3,5, if u uze the 5,3 and update to the 5,3,5 u will seeBR
