Page 4 of 25 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 361
  1. #46
    matekhr's Avatar
    Croatia
    Is there any solution to "downgrade" from xprog-box (unregistered) back to xprog-m v5.0?
  2. #47
    Apr 2011
    Quote Originally Posted by micromax View Post
    reading/writing algo is in *.boo files not in atmega. boo files is same in xprog 5.0 and xprog box.
    in blue box yellow man mount bad quality elemnets and upgrade atmega not solved this problem.
    I think you're wrong. "yellow man" mount mosfet transistor instead npn transistor with series B and BE resistor. In this case firmware very helpful. See xprog-box firmware issues, they solved this problem. I think *.boo files not firmware configuration files.
  3. #48
    Apr 2011
    Quote Originally Posted by matekhr View Post
    Try to contact with xprog-box software providers, maybe they will be able help return to innocence
  4. #49
    Bishop c4's Avatar
    Feb 2010
    chess board
    Quote Originally Posted by forumams View Post
    that statement sounds to good to be true, the main point of that offer seems to be the surrender of the clone not the catch and release situation.
    but who knows, hopefully youre right but still sounds pink.
    Regards
  5. #50
    Thanx bram380 work perfect
  6. #51
    DK Veteran wsc's Avatar
    Aug 2009
    GR
    i get f***en device is silent after this modi
    any suggestion???
    Smart car engineer ,
  7. #52
    mecale's Avatar
    Jun 2009
    ISTANBUL/TURKEY
  8. #53
    DK Veteran agabna's Avatar
    Jan 2010
    Default device is silent
    Quote Originally Posted by bram380 View Post
    Setup v5.3 until finish, then copy some files from v5.3 to v5.0 software.
    But don't copy 3 files *.exe & *.xml
    Run v5.0.
    hello
    i update it to 5.3 and i copy all the files without the 3 files .exe+xml
    but the device is silent
    can any one help
  9. #54
    bram380's Avatar
    Aug 2009
    Indonesia +628153111774
    If update the firmware, xprog-m will be not working.
    So need activation code from developer.
  10. #55
    Aug 2009
    GR
    aha nice...........................
  11. #56
    Jul 2010
    ALGERIA
    and if someone read the firewire in atmega (after update to v5.3 and registration) and upload it here
    i think that any one can update his xprogm to 5.3v without probleme
    upausb can read atmega
  12. #57
    bram380's Avatar
    Aug 2009
    Quote Originally Posted by grinovsky View Post
    Good idea...
    ATmega is locked, so need hardware attack to get all dump.
  13. #58
    Jan 2010
    hello
    i have read the michrochip 93lc46b and i found it empty just ffffff
    so if any one can read it to check
    but i dont know if it can slove it
  14. #59
    Jan 2010
    i have old xprog i can try ot read the pic with upa can u explain more
    i just whant to go back to 5.0
  15. #60
    DK Veteran elchip's Avatar
    Nov 2009
    EU
    Post
    Good idea...
    Time out sorry who have - have...
    Regard's
    [I]Automotive Electronics Solutions
    Mercedes-Benz Reverse Development Engineer ...
    Mercedes CFF 2010-2017 CFF all models all modules
    Vediamo help flashing over teamviewer ...
    JLR SDD online + offline ...last official ...
  16. The Following User Says Thank You to elchip For This Useful Post:
    bouchmid (10th January, 2014)
