Results 1 to 1 of 1
    maaxxyy's Avatar
    North Pole
    Default Bosch ME7 Hybrid
    Hi guys i want your feedback on this ecu, 0261206074 Bosch Hydrid, corsa-c 1.2. No problem with immo or running really, although cam sensor keeps flashing codes up, sensor tested all ok. I removed the ecu to visually check it for water ingress etc. Popped the back off and noticed 1 wire not soldered to any thing in particular. Has anyone got any pics so i can compare. The other fault is no speedo reading, already installed used cluster and programmed, repaired cluster harness plug, extended harness and replaced new connectors. I have tested the speed sensor on the left front wheel, exactly as autodata says, but when i have my multimeter connected to pin 59 and to earth the speedo starts to work, not correctly but does work. I was hoping the cam sensor fault and the speedo fault may be related, hoping someone can show me a pic of a good working ecu,to compare. Thanks
