Results 1 to 4 of 4
    motortech
    Guest
    Default Need Help Immo OFF file Renault Sagem Safir II Mod B
    Hi please need immo OFF, Renault Sagem Safir II attach Photos. Many thanks
    Oct 2010
    Search TMS374decoder. This software present on DK and work perfect.
    Here, I have simple soluce for you:
    1?) CUT immo line pin 30
    2?) FIND 27C512 or 28F512.
    3?) Connect ECU in car
    4?) With wire connect pin 22 or 23 with pin 16 (of flash 27C512 or 28F512) in short time (connect, no connect, connect,......) until the injectors and fuel pompe work....
    5?) So try to start car, normaly car work at 2500 at 3000 tr/min
    6?) Stop car, DISCONNECT battery while 5 min and connect it again
    7?) Car work good
  4. The Following User Says Thank You to CIRCUIT.FR For This Useful Post:
    martinracing (19th April, 2016)
    KILL_THE_IMMO's Avatar
    spain
    JUST A SIMPLE QUESTION
    WHY normaly car work at 2500 at 3000 tr/min????????
    THANKS
