Here is a translator for Tom Tom poi files to Mcguider upi file format
Moved > Satellite Navigation
Doesnt seem to work, takes an 85k OV2 file and makes a 1k UPI file :-{
has always worked for me. post your file and I'll have a go at translating it for you.
I hear the POI's for version 7.7 have changed. Will this converter work, is it just filename change?
I do not have the latest version so I don't know if it will work for you.
McGuider 7.7 (2009) and Sygic Mobile 2009 use a unique database format for their custom POIs with the extension .UPI. Unfortunately it is slightly different to the format used in McGuider 7.5 (2008) and Sygic Drive so the previous instructions and software do not currently work.
Sygic (the programmers behind McGuider) have released a convertor to create UPI files from tab delimited text files of the right format. It only supports a single file conversion at a time but it does support command line options which allow batch files.
here is the new translator
with file this time
I just removed loads of "THANKS" posts!!!! use the thanks button at the bottom right of the post you want to thank. PLease!!!!!!!!!!!!!!!!!!!
The Falkirk Wheel.The only rotating boat lift of its kind in the world
Will this work for Sygic running on windows ce devices?
TIA
yes
I used it on a htc running windows CE
When I have the file with the POI, how do I get in the phone, and in which map?
tks
kjeld
How How to use
Sorry but how do I download this attachment? Looked in FAQs and no help...
I am using Firefox running under Ubuntu - when I click on the attachment, I get a blank new browser window and there don't seem to be any relevant options when I right-click...
Sorry for being a pleb - any help appreciated...
