Page 1 of 2 12 LastLast
Results 1 to 15 of 19
    Junior Member goldrunner9k's Avatar
    Dec 2008
    Manchester
    Default McGuider POI translator
    Here is a translator for Tom Tom poi files to Mcguider upi file format
    Administrator
    Devilfish's Avatar
    Feb 2008
    Moved > Satellite Navigation
    Jan 2009
    Doesnt seem to work, takes an 85k OV2 file and makes a 1k UPI file :-{
    Dec 2008
    Manchester
    has always worked for me. post your file and I'll have a go at translating it for you.
    Apr 2009
    I hear the POI's for version 7.7 have changed. Will this converter work, is it just filename change?
    Dec 2008
    Manchester
    I do not have the latest version so I don't know if it will work for you.
    Dec 2008
    Manchester
    Default full reply for Mc Guider 7.7 users
    McGuider 7.7 (2009) and Sygic Mobile 2009 use a unique database format for their custom POIs with the extension .UPI. Unfortunately it is slightly different to the format used in McGuider 7.5 (2008) and Sygic Drive so the previous instructions and software do not currently work.
    Sygic (the programmers behind McGuider) have released a convertor to create UPI files from tab delimited text files of the right format. It only supports a single file conversion at a time but it does support command line options which allow batch files.
    here is the new translator
    Dec 2008
    Manchester
    with file this time
    Jun 2009
    Quote Originally Posted by goldrunner9k View Post
    V.I.P. Member Dreamer's Avatar
    Apr 2008
    Glasgow area
    I just removed loads of "THANKS" posts!!!! use the thanks button at the bottom right of the post you want to thank. PLease!!!!!!!!!!!!!!!!!!!
    The Falkirk Wheel. The only rotating boat lift of its kind in the world
  11. #11
    Aug 2009
    Will this work for Sygic running on windows ce devices?
    TIA
  12. #12
    Aug 2009
    Manchester
    yes
    I used it on a htc running windows CE
  13. #13
    Sep 2009
    When I have the file with the POI, how do I get in the phone, and in which map?
    tks
    kjeld
  14. #14
    Sep 2009
    How How to use
  15. #15
    Jun 2009
    with file this time
    Sorry but how do I download this attachment? Looked in FAQs and no help...
    I am using Firefox running under Ubuntu - when I click on the attachment, I get a blank new browser window and there don't seem to be any relevant options when I right-click...
    Sorry for being a pleb - any help appreciated...
