Results 1 to 15 of 16
    DK Veteran neriuks007's Avatar
    Default ford focus 1,6tdci fap
    i have ford focus 2005 1.6tdci with fap i remove fap with ecusafe2 in ecu fault p1187 ecm incorectly coded. please help remove corectly.
    the fault is probably not in the file, the problem is that you have flashed the ecu via OBD probably and the ecu+injector coding is gone. if the engine starts, then you need to restore engine ecu coding plus injector coding with a tester, probably VCM. if the engine doesn't start, then probably checksum is wrong.
    the car starts but this fault in ecu.i have vcm clone,what to do me?
    Feb 2011
    What tool you use to flash
    i use mpps clone.
    Feb 2011
    Did it ask for waiting time 3 min after writing, maybe injector coding or slightly wrong checksum
    I?m not shore, but i think that some maps could be on other parts of flash that MPPS don?t read.
    Best way is using BDM, if something goes wrong you always have original dump.
    If you mod the file from ecusafe and didn?t correct the checksum with OLS for example than you have it wrong.
    If you program the original that you read in first place, that error is gone ?
    Try this file, it have only checsum correct on OLS
    injector coding and engine ecu conding are both gone. restore them with VCM.
    i have china clone off VCM,can i do coding? where is this function?
    Enter in injection=>enter injectors code...
    this is in programing? in my vcm programing not working,need to update vcm?
  13. #13
    In injection menu coding=>manual update=>enter injector's code.
  14. #14
    Funny thing is that for all possible useful answers on this topic there is not even a single thanks from topic initiator...nice...
  15. #15
    i will do it only on next week. thanks friends
