Page 4 of 19 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 285
  1. #46
    Nov 2010
    Quote Originally Posted by handyguy2002 View Post
    this file is not big enough, my box is saying invalid file needs tobo 4 + mb
    Thats funny although Ive not used it yet I have downloaded it and unrared it and it shows as 4mb.
  2. #47
    I used 7-zip to unpack with no problems.
  3. #48
    Quote Originally Posted by zoomaz View Post
    Here is my Patched firmware for those who dont want the "Test Version" screen
    I am using winrar 3+ and the above files wont extract to any more that 1.6mb
    so i don't know if the version winrar I have will do winzip, but I would have thought that it would do,,,
    anyway i've getting a working test version els where and am happy now
    so thanks to all who has helped
  4. #49
    Firmware Openbox S9HD Europe 17/06/2011
    The manufacturer says:For Europe version software, its mainly features are as follows:
    1.updated mediaplayer to support some video formats--VCD(MPEG1),DVD(MPEG2),AVC,MP4(H.264)
    2.modified multi-cas read cards.and menu to disable EMM.
    3.add Indonesia language
    4.updated Slovak language,add Czech language
    5.updated Russia language,add Persian language
    6.modified some biss encrypt to decode biss channels
    7.added C Band LNB local frequency:3620MHZ
    8.added local time setting ---- bangkok/jakarta GMT+7 .
    9.added patch to support softcam.key format.
    10.modified some HD channels playing reboot problems
    11.modified background connect to internet
    12.add to 32 FAV list
    13. Add HDMI and AV output at the same time
    https://rapidshare.com/files/3945367..._EuropeVer.zip
  5. The Following User Says Thank You to sakin For This Useful Post:
    MAX2504 (10th October, 2014)
  6. #50
    Quote Originally Posted by Timmaa View Post
    Thanks zoomaz. Something I've noticed though; 'The Antenna Setup', 'Single Satellite Scan', 'Multiple Satellite Scan' and 'Transponder List' sub-menus of the 'Installation' menu are greyed so you cannot do any scanning with this firmware.
    edit: It also seems a little less stable generally. It's locked up a couple of times whilst I've been doing the factory reset and updating my channel list and other files.
    This is a minor bug in the firmware. I found that by going into the satellite list menu, deselecting the satellite, pressing menu, then going back in and re-selecting the satellite and pressing menu again, the scan menus are ungreyed.
  7. #51
    Jun 2011
    Default Asian sats
    Loaded the firmware for the Asian sats from this site http://www.yojiatech.com/index.html it had the European sats on it when I brought it which were no good for me living in Australia.
    Managed to set it up on Optus C1 but it keeps rebooting at various intervals which is a real pain.
  8. #52
    Apr 2011
    Exclamation
    Quote Originally Posted by sakin View Post
    i dont wanna be a party pooper,
    but this Firmware is not from the manufacturer.
    Rebooting bug still remain on HD Channels, im my case, MGM HD. Channels freeze, and somtime the sound dissapear.
  9. #53
    Nov 2010
    great work flip
  10. #54
    Firmware from 21/06/11:
    From another sites feedback.
    Backup your old firmware and settings first and then perform a Factory Reset before any firmware changes.
    Features on Openbox S9 Firmware 21/06/11
    Favorite Groups extended to 32 groups
    EPG Improved - especially 28E
    Satellite Scans still Blanked Out - Just go to =>Satellite List - Select the satellite you are on at that time eg. 28E => Press OK => Exit => Go back again and select 28E again => Exit and channels scans should be selectable again
    Media Player - Not tested by me
    Slower response to remote control
    Improved overall stability (ATM!)
    Let us know what else you find.
    Good Luck.
    Reported MKV files now play ok in media player!
    Thanks to fanjo at sataid for this info.
  11. #55
    Dec 2010
    Just upgraded to this.
    No problems so far, media player plays MP3s, MPG, MP4 & MKVs but not AVIs, well at least not for me.
    Now only if they could fix the EPG
  12. #56
    Feb 2011
    @Manic01 - What are the EPG improvements on 28E
  13. #57
    MANIC- Do you know if the new firmware 21/06/2011 would kill a clone box?
  14. #58
    Quote Originally Posted by bernado View Post
    I can't see any, I just posted from another sites feedback.
  15. #59
    Feb 2011
    Quote Originally Posted by Manic01 View Post
    Bah. A member from another forum has noted an EPG increase of several days on a, lets say 'exotic', paid for channel that's not on 28E. So it looks like the EPG is as good as it's going to be on 28E, due to the EPG data simply not being available outside a Sky or Freesat setup.
  16. #60
    It can be got on TM5402 etc so is def poss with some work on openbox. Down to openbox team to fix.
