hello guys i have 95 e36 316i with e39 528i engine swap. e36 28 engine wiring loom.
my problem is that i have i think abs problem and car revs when driving at 5k rpm.
can u guys delete abs in ecu file please? thank you apreciate it
https://mega.nz/folder/yeQ1haQJ#MCRIvwsfZBkkDpSEK9bTMw
please do it in immo off file
joao59 (29th May, 2020)
i wanted to use the Lambda 1 gave me but when i try to download keeps telling me to log in and once i log in it redirects to login page again xD . Can someone help urgently
Hello guys it seems the file Lambda made for me still didn't delete the abs system or the limp mode on the ecu. Can someone help me guys?
E39 m52b28 engine swapped on e36 16i 1995
Immo is already off in the file but because of abs speed signal is different from e39 to e36 the car is in constant limp mode revs 5k rpm.
Someone able to solve this in file? Here is the linkhttps://mega.nz/folder/yeQ1haQJ#MCRIvwsfZBkkDpSEK9bTMw
Vanos will work, but won't rev above 5k rpms. You just need to connect ECU pin 15 to rear right wheel speed signal from ABS and everything will work.
siemens 5wk9 032 d13 dme ms41.0
can anyone remove the immobiler from this flash reading am28f200 please
evss (3rd June, 2020)
Hello Guys
Please immo off this for me from a BMW E36
MS41.0 part no. 1 429 861 5WK9 0322
DUMP IS 28F200
Regards and big thanks
bonecrusher (22nd June, 2020)
Hi Guys,
need please Help
MS41.0 Index11
5WK90322
1 429 861
FLASH ORI
MS41.0 Flash ORI dump i.o.rar
Please need IMMO OFF
Thank You
Here immo off.......
