Results 1 to 11 of 11
    Unhappy insite keygen stop working after dec 30 2011 ?
    does your insite keygen stop working after dec 30 2011 ? mine does ? any body else have this problem ? I can make keys up to dec 31 but not jan 2012 ? i get errors on both my keygens ?
    DK Veteran RSwire's Avatar
    your girlfriends house
    My kg works sorta good, I usually make keys till 2015-2016 but it takes a bit, I do get errors at times, I just keep trying till the key spits out, it is a little annoying but it does work.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    Do you mean it wont make keys after 2011? or the keygen itself stops working after 2011 ?
    Mar 2011
    Quote Originally Posted by dsskaren View Post
    If it says "unknown error" just hit ok and then try again. Sometimes you have to do it 3 or 4 times to get it cough up a keygen. Some PCID's must be a little more complicated than others to figure out.
    Same here. Sometimes I even have to close the keygen and then relaunch it to get it to work but most times it's just like everybody else says it takes two or three times.
    What operating system are you using it on windows vista, xp , 7 ? had alot of trouble with vista and 7 after the security updates
    Thanks guys ,will keep trying .
    I use xp pro
    Who's kg is it ? my carsoft v2 is all good
    Dec 2010
    the keygen works after 31/12/2011...
    I make keys to 2020 usally, as for the kg working itself after 31 / 12 / 2011 I won't know that till then
    Quote Originally Posted by B.2 View Post
    HI have sultan ,carsoft & bp got them working after a couple tries . thanks guys
