Results 1 to 4 of 4
    Default laguna 2 dash 908az60
    hi i can read the dash from laguna with upa and i ask if i take a new mcu and i put on it i can right with upa or only the eprom file and not the flash?because i read only eprom and when i put to read all memory i upa makes 10 minutes to read.i must take the 908 programmer or the xprog do the job?to read write the eprom and flash?thanks
    i read the mcu very easy with out lift any pin and only put power from back on dash and work !!!!if not put power said error
    DK Veteran Digamax's Avatar
    Serbia
    Quote Originally Posted by tas_daz View Post
    Hi, Use 908 ETL programmer.
    Best regards
    Vladimir
    only 908 etl original or and clone work?the xprog m not read flash?because i want to take it?thanks
