I'm kinda curious as to what else the passthrough function can be used for and if it would be possible to use it on other cars for other purposesOriginally Posted by scotte
well i encountered my first problem with the gm reflash
the program can talk to the scanner but the scanner needs the old style cable with a 3306-12 gm reflash insert to see the car
evidently they either didnt build the smart cable to cover that insert or they never updated the reflash app to be smart cable compatible
Well I never planned on including the gm Sps programmer. But it was requested and I got lazy and didn't want to make a separate patch to include it. But i'm glad it's working though. Anyone got a 3306-12 ssi they want to crack open to take high-res pics of the pcb? I might have it. I'll have to double check later. Btw I have opened up a smart cable.. And believe me.. It would be nearly impossible to do. It has a antera max micro controller. And a whole lot of surface mount components.. Anyway so did I fix the infotech issue for you scotte?Originally Posted by scotte
infotech is working great
thanks for getting the gm reflash app working
i firmly believe its working as its supossed to but otc quit selling it before system 3.0/smart cable and i dont think they ever thought about anybody using it with a smart cable
when you bought the reflash package back in the day you got the expertec dvd,the gm usb security key(goes into the computer to unlock the sps database) and the reflash ssi
there is a manual for it in ngis/ngisuserguide/
its a somewhat interesting read (it also covers reflashing with the tech 2)
Scotte
This is very good news and I cannt wait to get onboard. It seems my new 2 Gig CF card is not good so I must go buy another one.
If I can recall correctly the Expertec DVD is a compilation of all the different flash files for GM up to the year of the DVD release, now you must go online to get these file. I already have GM SPS stand alone that goes all the way to 2007 so much can be done if we get this going and by the sound of it it seems we are there.
OTC make it to only work with the 3306-12 insert you are 100% correct.
If we get the configuration of 3306-12 mybe we can adapt one of the other smart insert to work because once we get the smart cable you really dont need much of the inserts.
This is GREAT I love it!!!!!!!!!!!!!!
Thanks again to all those who have help to make this possible and SUPER BIG THANKS TO BIBMS.
Oh by the way The OTC Genisys emmulate the TECH-2 as far as reflashing is concern so that why the readme file are the same as the original THEC-2. There are a few other company that does this emmulation as well, Ease Diagnostic is one of them EASE Diagnostics - The Leader in PC-Based Automotive Diagnostic Solutions
the expertec dvd is a limited version of the sps tis2000 software
(not having the tech2 updates,tech2 viewer etc)
the dvd i have covers up to 2006 or 2007 iirc
the full gm sps program will work with the (pass thru only)
if you can get a ssi configuration or a way to make the insert happen i can complete my testing (its fairly easy as i have both versions of gm sps,the genisys,a tech 2 and a offboard pcm flashing rig with a spare pcm sitting on my desk
I have never use there tool but I have read there setup and its the same as Tech-2 for Tis2000
The pdf I upload is from Ease site at
http://www.obd2.com/support/reprog/d...is2000-req.pdf
If we can't find anyone with the 3306-12 I remember reading somewhere that flashing should be possible on pre obd gm cars I think that's what the sps manual said
Today I bought a 2Gig SanDisk Ultra CF card and loaded the 2010 update, the Asian Diagnostic software did not work well, whenever I choose a manufacturer it starts loading that mamufacturer file, then it comes back to the main menu with the list of all of them.
Now I an reformating the CF and will reload. I also notice that I did not get the pop-up for the ABS/AirBag smart card during install so the AirBag Icon was not there.
I will see if it comes back after I reinstall.
Yeah that's right, I still can see tpms, but ABS has been integrated into the main program. Or atleast that's what the current flyer saysOriginally Posted by NightDragon
