can someone help I tray to read hc05b8 mask d33j opel immo with upa usb and nothing hapen it say device not responding
tray to tuck out procesor and still nothing.
wher I doing wrong?
wher I doing wrong?
you might have damaged it trying to read it in circuit incorrectly and so now it wont read at all, sorry to sound so negative, I always remove the chip, its the safest way if you dont know if the programmer will read it in circuit properly or not, hope you get it sorted out ok, good luck
ok thanks.can you tell me wich 2 track I nead to cut when I read with upa usb.
and I read this mcu with Xprogm it comes last day.job done
ok thanks I will do that
Or use device for read pincod via k-line&boot point
You need every tool in the book, to do this auto locksmith job.
and proper pin are???
Just remove it my friend read with xprog post dump someone give you pin 10 minute job.
Alternatively find yourself a used immo unit with matching transponder because this is immo 1, you can program engine ecu into used immo with transponder without the need for codes using opcom.
two very easy jobs.
Your choice??
Car runs again, customer is happy, you get paid and we can close this thread.
With upa allways works
Everything is easy when you know how
Thanks to Claudiu_dar for picture,good work.Pins are 11(PD3),19(IRQ) and if haven't connection lift pin 22(TCAP1) too.But in most cases only two pins must lift.
