Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    igorr's Avatar
    Aug 2010
    Default opel immo hc05b8
    can someone help I tray to read hc05b8 mask d33j opel immo with upa usb and nothing hapen it say device not responding
    tray to tuck out procesor and still nothing.
    wher I doing wrong?
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Jul 2009
    In my immobox...
    You must cut 2 track in order to read in circuit.
    4C7570755F73616E64755F696D6D6F5F736F6C7574696F6E73
    DK Veteran gtmech's Avatar
    Jul 2010
    Hell
    you might have damaged it trying to read it in circuit incorrectly and so now it wont read at all, sorry to sound so negative, I always remove the chip, its the safest way if you dont know if the programmer will read it in circuit properly or not, hope you get it sorted out ok, good luck
    igorr's Avatar
    Aug 2010
    ok thanks.can you tell me wich 2 track I nead to cut when I read with upa usb.
    and I read this mcu with Xprogm it comes last day.job done
    mastaflex's Avatar
    Jan 2009
    FR47310
    Quote Originally Posted by igorr View Post
    wher I doing wrong?
    better to read it external, never had problem using UPA
    Jul 2010
    Hell
    remove chip from board and insert into xprog-m adaptor and read it that way
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by mastaflex View Post
    Mcu has security unless pin code has already been entered in vehicles life.
    So best to read as gtmech says remove it and use xprog-m.
    You need every tool in the book, to do this auto locksmith job.
    igorr's Avatar
    Aug 2010
    ok thanks I will do that
    avital's Avatar
    May 2010
    vagimmocalculator.com
    Or use device for read pincod via k-line&boot point
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by avital View Post
    If we had seen these 10 yearsish ago would of been very useful, but now these old hc05 immo 1,s are old hat.
    Very good tool if we had it ten years ago though m8
  11. #11
    stoyanov's Avatar
    Jun 2010
    42 75 6C 67 61 72 69 61
    Quote Originally Posted by lupu_sandu View Post
    Confirmed,no problem to read in circuit this MCU with UPA,you need to lift proper pins.Tested many times.
  12. #12
    igorr's Avatar
    Aug 2010
    and proper pin are???
  13. #13
    obdmaster's Avatar
    Never never land
    Just remove it my friend read with xprog post dump someone give you pin 10 minute job.
    Alternatively find yourself a used immo unit with matching transponder because this is immo 1, you can program engine ecu into used immo with transponder without the need for codes using opcom.
    two very easy jobs.
    Your choice??
    Car runs again, customer is happy, you get paid and we can close this thread.
  14. #14
    Top Poster Claudiu_dar's Avatar
    Apr 2009
    Romania
    With upa allways works
    Everything is easy when you know how
  15. #15
    stoyanov's Avatar
    Jun 2010
    Thanks to Claudiu_dar for picture,good work.Pins are 11(PD3),19(IRQ) and if haven't connection lift pin 22(TCAP1) too.But in most cases only two pins must lift.
