Results 1 to 11 of 11
    makura's Avatar
    Default opel pincode calculator
    Hi guys
    Just a quick one,is there a tool i can use to calculate login pin codes for opel/vauxhal from dump,something either than icc immo code calculator?
    Hello
    Which module you want to get the pin for?
    if you have a programmer try to drag the dump file from immo box like the one in the attach file
    adn send it to me i will send the pin
    makura's Avatar
    Thanks m8,i could do that but how many times?i deal a lot with these opel's and Vauxhall's i can read the dumps from the micro's,and at times i need the pin code instantly and wont have the luxury of waiting,if i am at my workshop i don't have a problem because i can use my desktop and my TMS370 programmer that will not work on laptop because of the comport issues,it wont work with a usb to com cable.
    Any way i will send the dumps as i have no choice at times.thanks again mate,if you can PM me your email,ki think that would be faster for you to get it and respond.
    GB
    is there something for pincode reading MULTEC Delco Z16XE engine opel vectra .. t-300 asked me for outcode to encode pin .. do i have to read immo box ?
    EARTH
    Default use sof for zed bull
    use sof for zed bull,
    use of soft sierra zed works without being connected, pin cod ok
    http://www.digital-kaos.co.uk/forums...82/index4.html
    effi.rar good luck
    ALEXEI's Avatar
    here is the sw that you want
  7. The Following 26 Users Say Thank You to ALEXEI For This Useful Post:
    artur12 (5th September, 2020), asto (28th October, 2020), attila803 (21st July, 2021), boxsport (27th May, 2022), BUSUIOKPETRU (19th June, 2018), cjawahir (3rd January, 2019), criss2000 (22nd November, 2018), daily drive (30th March, 2022), dzevad (13th April, 2014), ecufix (16th September, 2014), Fuller (22nd December, 2020), gobe (15th June, 2023), Jashmine1983 (31st January, 2015), k1champion (8th January, 2015), Lauris1988 (26th September, 2017), mariantv (25th August, 2022), osmaster811 (30th September, 2018), Recoder (14th July, 2015), reglissebudy (4th April, 2019), samatii (1st December, 2018), sieman (21st March, 2023), subarurex (20th March, 2024), tomxx (27th August, 2018), TurboR (27th November, 2023), wessam101 (4th August, 2020), willyboy28 (7th September, 2021)
    kty's Avatar
    RO
    Friends,
    Code OPEL code read by OBD is "OPEL ALL now" is without fail !
    Find here detailed:
    Aparate diagnosticare auto,interfete profesionale diagnoza auto,testere profesionale,programatoare ecu,programatoare borduri auto
    or
    SMOK
    Quote Originally Posted by toximatic View Post
    These can read PIN from engine ECU by OBDII:
    Carprog
    Avdi Opel Commander
  10. #9
    speedy100's Avatar
    Athens
    Quote Originally Posted by kty View Post
    Friends,
    Find here detailed:
    or
    SMOK
    What cable is this working with?
    B.R
    Knowledge is to share... so if I have helped just press [Thank You + Rep.]...
  11. #10
    speedy100's Avatar
    Athens
    Quote Originally Posted by datapage View Post
    effi.rar good luck
    Not working... is asking for transponder.mbd file.
    Zed Bull also not loading...
  12. The Following User Says Thank You to speedy100 For This Useful Post:
    mister opel (13th December, 2020)
  13. #11
    Sep 2016
    south africa
    Tnx. Just what i needed
