Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Meat-Head's Avatar
    Quote Originally Posted by EssexTech View Post
    B1029-- bulb in cigarette lighter and B1030 was the rear tail light connector pins
    That's shite, thanks for the update
  2. #17
    Liteace's Avatar
    Mar 2009
    On a rock
    Can anybody tell me what code B1029/1030 fault codes are on a 147 JTD. I need Alfa Romeos actual description
    Quote Originally Posted by Liteace View Post
    B1029 cigarette lighter & air con = earth short or short to B+
    B1030 fuse for brake lights = open circuit
    so as far as your concerened 2 blown fuses, as far as punter is concerned,
    "multiple high resistancse postive connections in the fuse box area"
    The scanner was nearly spot on
  3. #18
    Senior Member EssexTech's Avatar
    Yes it was close .
    Anyway you peeps give me a shout if you have hassle with the french and korean shite
  4. #19
    morocco
    hay may frand can my damp alfa romeo 166 for bosch0261 204 032
  5. #20
    If you require a ecu dump for your car then post it in the ecu section as you will recieve better feed back
    HYUNDAI AND PEUGEOT TECH
