do u mean the admin password or do u mean the windows activation code??
Hi, I have a Toshiba Satellite Pro with Windows 7 o/s. I originally installed AVG 90-day trial. Unfortunately the kids picked up something that crashes Firefox all the time so I cannot purchase an AVG license and update antivirus defs. So i did a restore back to a point a few months ago, rebooted, and now the windows password does not work.
How do i get Windows 7 started if i cannot remember the password?
I saw a billboard on the way to work this morning that read "Future Events."
Well, that's a sign of things to come.
I remembered and successfully input the "power on" password. But my daughter set up an account in W7 and it's the only account and that's the password i don't have
Milo
Download the Hirens cd.. there is a windows password work around thing in it if I remember correctly
Once you disable the password it will boot through to windows
As siren says hirens coot cd will fix it have used it many times
go get this software and with it you can change or rest the password as you want it call Winternals Administrators Pak
Have you lost your windows 7 password?
Now, we'd commend you a professional Windows password recovery software? Windows Password Reset Tool as your reference.
Time: 5 Minute!
Recommend: +++++
As an easy method to reset Windows 7 password , there are only four steps as follow:
Step1: Download Windows Password Reset Tool and install it.
Step2: Burn the ISO image file onto a USB flash drive.
Step3: Boot up your Windows 7 PC by the bootable burned USB in minutes.
Step4: Remove the forgot Windows 7 password on the operation interface and logon PC without password.
For different reasons I had a similar problem with vista i'm sure all I did was start in safe mode then run as admin, reset passwords ...
