Results 1 to 8 of 8
    Default help find maps 27c512
    hi there,
    cheers from Portugal, im doing a home made tuning project on my 106 rallye, want to roll it in ostrich2 and tunerpro, live map, i took the chip out today and read it, open it with ecm and drivers but after comparing the addresses with winols clearly that maps location are wrong...
    1st time doing this if any one is willing to help i will be appreciated
    i need to find the maps and any other help to make the xdf file on tunerpro would be good but for now find the maps is my main concern
    thanks in advance
    here is the file
    scarymistake's Avatar
    Apr 2009
    Europe EN
    Quote Originally Posted by anhuka View Post
    hi there,
    thanks in advance
    here is the file
    send us more info from the ecu
    In the meantime try this.
    He is from ECM6.3 (Driver 106RALL2)
    thanks for help mate
    that was the program i tried, with that driver, but when i compare the addresses that ECM gives me in WINOLS they make no sense, the 3d view is all aggressive ups and downs, parts of the map are empty ... are you sure those address from that driver in ECM are right? (if so things will be much easier)
    sorry my bad here is the ECU info
    car: 106 Rallye 1.3
    ECU: MAgnetti Marreli IAW 8p.40
    the checksum ecm says is
    Cks: B59A
    Size: 65536 = 0x10000
    there are other numbers on the ecu label , is needed any more of them?
    thanks in advance for the help much appreciated
    edit:
    here is every nr that is in the ecu label
    Magneti Marelli IAW8P.40
    J296XT54 144 94
    16143.124
    9620697280 12v
    dimitar's Avatar
    According to checksum:
    PEUGEOT 106
    1.3L 8V RALLYE 98HP IAW8P IAW 8P40
    Ver. 1.00.012
    50w Soldering Iron
    Chisel
    Sometimes Hammer
    Netherlands
    There are 2 fuel maps.9 loadsites 21 speedsites (on my head) These are correction maps zero is AFR 14.7.
    From 0 to 7F is richer from FF to 80 is leaner.
    Ignition is same like Bosch. Also WOT map.
    RPM limter is 21000000/16bit value. There are 2 values ignition off ignition on.
    mexanico1971's Avatar
    portugal
    Default heres AFR
    here AFR, for this car ?!
    106 xsi unidade marelli iaw 8p.4016143.144
    9625002780
    thank"s in advance
    BR
    Feb 2013
    Any news for an xdf file?
    Oct 2021
    Default i m looking for XSI or rallye S2 ecu file
    Quote Originally Posted by Gyubrush View Post
    i m looking for XSI or rallye S2 ecu file ?? need help thanks
