Results 1 to 8 of 8
    V.I.P. Member lagerland's Avatar
    Sep 2010
    Right ere Right now.......
    Default fuse keeps blowing.
    I have a 2001 ford foucs and as of late it blowing the fuse to the petrol pump about twice a week.Someone gave a unit out a 55 mondeo but tells if take it apart the pump assembly is the same as the 2001 foucs can anyone confirm that for me please thanks in advance..............
    I am not sure you realise that what you heard is not what i meant !
    racin-snake's Avatar
    Jun 2009
    the earth wire probably is burnt on your focus or short to earth
    you could change the actual pump without the swirl pot maybe ?
    but the swirl pot on these has a track card for the fuel sensor and the swirl pot is clipped (bayonet style ) into the tank
    but might be the same actual bosch pump motor
    i could be wrong but housing (swirl pot) wont fit
    hope it helps
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Sep 2010
    Thanks racin-snake i will have a look at the earth first b4 i get to involved with it thanks again mate nice 1 ...........
    Meat-Head's Avatar
    there is a CONFIRMED rumor going around which states in Spain it is a daily job dropping fuel tank on a focus and fitting new pump.
    *THINK* your wasting your time, but worth a quick look, open trunk lhs rip the carpet out, the loom chaffs on the spotwelds
    HTH
    Meat
    Sep 2010
    thanks mate r take a look..........
    Jun 2009
    the earth burns out on the top of the pump motor in tank
    but check live before pump as meat head has said
    after the pump it wouldn't necessarily blow a fuse
    pre pump live to earth will
    check the loom and volt drop earth to pump think this one is deffo a tank down job
    hang the tank down a good bit dont remove it
    condensation in the tank causes the earth wire to burn out
    sometimes water causes short across terminals on the pump too
    Meat-Head's Avatar
    if could remember what car/ problem, would tell you, but some pile of crap, loom sits on spotweld on the passenger seat, front lh mount.
    can't rember at all, just know ended up stuffing some pizza box under it and charging the bloke the earth, check that before dropping tank, might have been some shitty rover, but it was a really simple one to find.
    Sep 2010
    Thanks again lads.............
