I just converted my Audi To Manual from automatic, but my ABS/ESP module is still looking for a connection to the TCU, is there anyway i can reprogram the ABS module so i can have my ABS working again and for it not to look for my TCU?
More info about your car would be helpful for example .......What Year it is, Petrol or, Diesel......... A2,A3, or A4 and so on...........But, to help your self you can have a quick look in here...................
You will also need to change the software coding in Engine ECU from Auto to Manual...........
Diagnostic Procedures - Ross-Tech Wiki
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
its a 2003 Audi RS6 4.2 Gasoline
Post a full autoscan from the car.
Ronan
try
ABS coding
06395
06595
06695
do you happen to know the Login code for the ABS module?
any advice? still no ABS here
What brakes do you have?
Follow these intructions (depends what ABS you have in car):
http://wiki.ross-tech.com/wiki/index...28Bosch_5.7%29
or
http://wiki.ross-tech.com/wiki/index...EDS/ASR/ESP%29
Hi , i do it twice with A 4 1.8 T , i change flash of engine s ecu with a manual flash with kwp2000 , you should try
Remove the TCU and recode ECU ,thats all .
dont work![]()
