Page 1 of 11 123456 ... LastLast
Results 1 to 15 of 162
    Default Professional Tuned File Request CLK270 CDI
    Is it possible that one of the experts in this field can make me a good tuned file.
    Thanks in Advance.
    ALGERIA
    yes;but must modifed more than 120 maps to make a good tuned file
    monitel_service's Avatar
    ROMANIA
    yes is posibil with 117 maps file
    Moon
    a good tune doesn't mean to modify all possible maps, but to modifiy those maps who makes a difference in a safe way. I am sick of seeing files with 5-10% on calibration-injectors opening time maps. Some tuners doesn't even know what they are moding and why. Mate if you want a good remap ask someone who can really do it and pay for it. It's the difference between a running car and a running-badly car
    You can get max power stock turbo and good soft about 235hp and 550nm, whitout smoke.
    When you change examble 320cdi turbos and 3bar map you can get over 250-270hp and over 600nm.. If your AT is good condition.
    edit. that all comes normal calibriation-injection time...
    Coolis.
    Member Autronic's Avatar
    The burned land (ITA)
    Quote Originally Posted by Mario32 View Post
    Thanks in Advance.
    Hi m8!!!
    Do you still need it??
    Fab
    Quote Originally Posted by Autronic View Post
    Hi m8!!!
    Fab
    Yes I still need it.
    Thanks in Advance.
    ALGERIA
    Thanks in Advance.
    did you speak about remap this
    Quote Originally Posted by grinovsky View Post
    Yes it is exactly that model in the picture.
    Thanks in Advance.
    That engine, about 10 map pack you have to change and couple limiter then you get about 235hp if you don?t find these limiter you get out about 200hp..
    very simple EDC15c6...
    Coolis
    ALGERIA
    mmmmm but the max torque limiter is set in original to 765nm so we have to increase this value!!!to get 235hp!!!
    Dec 2010
    EDC15C6 does not calculate in Nm. What you read there is fuel in mg/st. 765Nm is the value of an actual VAG 4.2tdi edc17 (800Nm) :-)
    This here is 76,5mg/st
    greetings,
    filecloud
  13. #13
    ALGERIA
    oh,in edc15c6 they have changed the unite of torque too!!!
  14. #14
    Normally soft mod (200hp and 400nm) you can get 80mg/st, but evrything is calculated 100mg/st..
    But you have solved how you can get request 100mg/st (normally max request is 80mg/st) and then you have find limiter.... what limited that 8?mg/st In this kind car (270cdi)
    When you get 100mg/st, you have to calculate AFR and you have to get more boost..
    And next make new linearisation map your 3bar map sensor... (originally 2.5bar)..and..and..
    Coolis
  15. #15
    ALGERIA
    before write all this numbers,try to analyse the dump and tel me why this car lost the power
    there are one reason,i let you search
