hello, I want to introduce me before of all.
I'm from spain, I'm industrial engineer and I work as a automotive teacher of professional formation in my country.
I am looking for soft/hard to flash and remap an EDC16cp39 ECU working with a citroen DW12MTED4 FAP (2.2 HDI 156 Cv) from a a c-crosser.
Galletto has no drivers for this ecu and the remap programs tha I found are in the same situation.
Thanks and excuse me if my english is not so good
best choice for me is the bdm .
you sure make a complete backup of your ecu in case of problem , sure not to have probleme with injector coding or other stuff . and in case of problem you will be able to make a real clone of your ecu into another . cheap on ebay
Thanks elchip and gzk.
The Crosser engine is the same of the C5 without biturbo and the ecu is different.
I found support for Outlander/peugeot 4007/c-crosser in the specifications of the Kess obd kit (v1) KESS OBD Tuning tool - ECUTRADE
What do you think about Kess?
I don't want to spend money if I'm not sure that supports this model. Principally It's for didactical use in my institute, because of that I need to learn using my car and apply it in my lessons. I have a long way.
Bdm suports EDC16+ CP3x Mercedes/Mitsubishi/Smart:
It means tha suports edc16cp39? What does "+" means?
