HD Glass 16 skins by shamann
Page 1 of 6 123456 LastLast
Results 1 to 15 of 80
    Sep 2010
    19
    Default HD Glass 16 skins by shamann
    while i am posting this skin here please note that this skin will work on almost all E2 receivers running almost any firmware.
    HD Glass 16 ver. 1.02
    - based on HD Glass 15 with new code, no more editining sys files...
    - you can configure via Menu->Setup->Setup Glass16:
    - black picon Providers and Sat by ftryskac, thx
    Enable permenent extrainfobar (change applied after restart GUI)
    Enable show address In ECM
    Enable Enhanced infobar ( show detailed ecm info, ecm line info auto changed to available caid and used caid from ecm, and bitrate - if enabled)
    Enable bitrate
    Change type if icons (mean ecm and base icons) - after change GUI is autorestarted
    this is an universal skin ready for any image meets sys compatibility with DMM image
    Sep 2010
    19
    HD Glass16 ver. 2.27
    - added detection of multichannel audio (new dynamic icon - audio)
    - fix timeshift osd messages
    - fix detection of ac3 audio in some **** images
    - added detection of marker and bouquet in channel selection screen (marker and bouquet picons by ftryskac, thx)
    - added support for
    warning: do not install on Nemesis 2.0 and 2.1 images
    Sep 2010
    19
    HD Glass16 ver. 2.30
    - added watchdog and autorestore after update ( when some skin files are changed after update of image)
    - small fix of screen 1 and 8
    - added the symbol of degree (sat position in channel selection screen and in infobar info)
    - changed the picon of bouquet (bouquet by ftryskac, thx)
    Sep 2010
    19
    HD Glass16 ver. 2.31
    - update of sat description
    - changed the piconProv of CSlink (piconProv by ftryskac, thx)
    Sep 2010
    19
    HD Glass16 ver. 2.32
    - Update of sat description
    - Changed the piconProv of CSlink (piconProv by ftryskac, thx)
    Working on VIX 2.0
  6. The Following User Says Thank You to RuberDuck For This Useful Post:
    bwj (29th September, 2013)
  7. #6
    Sep 2010
    19
    HD Glass16 ver. 2.33
    - added encoding.conf to autorestored files, when update of image is detected
  8. #7
    Sep 2010
    19
    HD Glass16 ver. 2.37
    -added option to enable simple baseinfobar ( showed when permanent extrainfobar is disabled)
    - added option to enable default Oled
    - updated detection of satellites
    - big update of piconSat (thx ftryskac)
    simple baseinfobar and default Oled are autorestored if skin will be updated in the future
  9. #8
    Sep 2010
    19
    HD Glass16 ver. 2.40
    -added slider background in all extrascreens - can be enabled/disabled via setup
    - big update providers (piconProv - thx ftryskac)
    - small correction in screen EventView
  10. The Following User Says Thank You to RuberDuck For This Useful Post:
  11. #9
    Sep 2010
    19
    HD Glass16 ver. 2.42
    - changed slider background in all extrascreens
    - added new volume "renderer" with value in %
  12. #10
    Sep 2010
    19
    HD Glass16 ver. 2.43
    - bitrate moved from enhanced to extrascreens using, now you can use it in any screen of extrasreens
    - added screen 9 with bitrate
  13. #11
    Sep 2010
    19
    HD Glass16 ver. 2.52
    - added screen 10 with bitrate
    - added screen 11 without ecm icons - for Ipbox with E2 ecm bug
    - added new option - ecm/caid info in ecmline
    - added piconProv - Satellite BG
    - added support for Verimatrix - caid 5601 - 36E
    - added new set of icons (5) - ecm/emm icons with caid logos
    - added new option: enable volume as a percentage
    - added new option: channel selection with pig
    by shamann
  14. #12
    Sep 2010
    19
    HD Glass16 ver. 2.54
    - updated piconProv (thx ftryskac)
    - changed option: enable default oled to Type of oled: glass16, default, only picon (use it only if you have oled pions in dir../piconoled)
    - added new option: menu type: with pig (options: Icons, List, with Pig)
    by shamann
  15. #13
    Sep 2010
    19
    HD Glass16 ver. 2.55
    - changes in setup: mapping moved from button "OK" to button "1"
    - added new option in setup (press button "2") - editing of the paths to picons (channel, provider, satellite, oled) - all paths are saved in /etc/piconPaths.conf, after change of the path, autochecking is started and show picons for actual channel
    - added HDD temperature in usercode
    - changed renderer for oled picons
  16. #14
    Sep 2010
    19
    HD Glass16 ver. 2.58
    - changed volume screen option to Type of Volume: glass16, percentage(with colored bar), colored gauge(gauge is automoved by value of volume and color is autochanged by value of volume)
    - changed picon_default of the Provider and added 1 new (thx ftryskac)
    - updated encoding.conf (thx Calokay)
    - fixed g16volume renderer
  17. #15
    Sep 2010
    19
    HD Glass16 ver. 2.59
    - fix tempfan control screen
