License code
DE3B FCD6 2529 BC52 D6
On highway truck only required.
Thanks in advance. I can't find my old keygen to create my own.
License code
A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
Please don't pm me for keys, that is what the forum is for.
If it helped, please use the thanks button, if thanks isn't enough use the scales.
I can't install newer version on that laptop. It's a dealer laptop without admin privileges but with a key, I could get this old version working. The alternative is using an old laptop with win95 and an even older version of cat et
Sorry but that key didn't work
The only way I know to hack the admin password is to reset it which I can't do. The laptop is still controlled by corporate head office so they still use the admin password to put in updates.
The only reason we need this version working is this is the only laptop with a serial port. Using the Cat datalink through an OBDII adapter is required to talk to a Cat in a GM truck. I've tried a USB to serial adapter to connect to the Cat adapter and still can't get it to work on the newer laptops. None of the other USB datalink adapters we have will communicate onto an OBDII connector.
The second one worked perfectly. That deserved a big thank you.
