Results 1 to 15 of 28
    Default PEUGEOT SID803 need virgin
    HI ALL
    can anyone to help me , I need virgin dump to this ecu
    eep 95320, ecu sid 803, SW9656412980 , HW 9655041480
    thanks in advance
  2. The Following User Says Thank You to manole For This Useful Post:
    alxbk (20th June, 2021)
  3. #2
    racin-snake's Avatar
    Jun 2009
    pin can be found but i dont have a virgin for this ecu if you have the pin for the car you need to put it in i can swap pin ?
    the pin on this rar is ....887J
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    hi racin snake
    can you give me the code from the old ecu , and thanks from good ideea
    Jun 2009
    MKFG is what this bin has code changed to 887J
    give it a go and report i can swap the pins around in the files if that can help
    benci1982's Avatar
    Slovakia :((
    hi. try this dump, this is virgin dump, original dump mod. (virgin login)
    pass pm...
  7. The Following 6 Users Say Thank You to benci1982 For This Useful Post:
    davidobd2 (15th December, 2018), kanzus (16th August, 2013), khalilo_de (5th April, 2013), mastaflex (12th October, 2013), mohamedkey (2nd January, 2014), Nabil1987 (26th November, 2013)
  8. #6
    thanks I try and come back with results
  9. #7
    benci1982's Avatar
    Slovakia :((
    hi. what's the result?
  10. #8
    This dump working?
  11. #9
    it's ok working
    thanks you all and especially to benci, yur solution is good
  12. #10
    alclot's Avatar
    Melee Island
    Quote Originally Posted by benci1982 View Post
    pass pm...
    Hi benci1982. Can you give me password?
    Thanks in advance
  13. #11
    credoline's Avatar
    Србија
    Can you please Benci1982 revirgin mine file (5WS40029O-T Siemens SID803 Peugeot 307 2.0 HDI). I have some problems and want to try to solve with revirginized ecu.
    Thank you
  14. #12
    Paris
    pass pm...
    Hello mate,
    could you give me pass please, I need virgin this ECU, I have already picode for car 307 2l 136cv.
  15. #13
    pass in pm
  16. The Following User Says Thank You to manole For This Useful Post:
  17. #14
    Paris
    thanks a lot m8, it work like a charm. I could restart car after recoding whole ECU (MPC+Flash+EEprom) and paired to BSI via pp2000.
  18. #15
    fafi10 see pm
