Results 1 to 5 of 5
    rossoelab's Avatar
    Italia
    Default Smart locked ECU help
    hello
    reading at the end of the flash with cock 1260 (boot mode) error message
    I did not know that one must first read the serial eeprom
    I have some hope to recover this ECU?
    Many thanks to those who can help me
    vuno01's Avatar
    Europe
    remove and read the eprom on a programer like
    gq 4x and then rewrite it
    and its fixed
    Dec 2010
    Quote Originally Posted by rossoelab View Post
    hello
    Your file is fine and your eeprom is also fine. Re-write the same stock file in the car again and the eeprom will correct itself. Switch gear to neutral before you flash and after flash switch ignition off and wait for the cluster to shut down before you try to start. Takes roughly 30 seconds. Important!
    greetings,
    filecloud
    rossoelab's Avatar
    Italia
    I rewrote the original file and everything is correct
    The ECU is back to work well
    thank you very much
    vuno01's Avatar
    Europe
    when you sayd its locked i assume that you could
    no longer read or write (Thats Lock)
